How do I connect my turntable to my RX-Z473 receiver. I can't find any input on the receiver for it.
djproaudio
  • 515 Answers
SOURCE: Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
SOURCE: Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Posted on Jan 17, 2009
lynchms
  • 93 Answers
SOURCE: yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
  • 7 Answers
SOURCE: Buzz coming from speakers on phono input
is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
Posted on Jun 21, 2009
  • 108 Answers
SOURCE: I have a new Yamaha RX-V365 receiver and an older
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Posted on Aug 30, 2009
Can i connect a turntable to a JVC RX-5020VBK receiver?
With a bit of effort: This receiver has a variety of auxiliary or "line" level audio inputs (CD, VCR, etc.) but none designed for a phono cartridge input. You would need an external phono preamplifier in between the turntable output and one of the JVC inputs to have sufficient audio level. (Some newer turntables come equipped with such a preamp, but most do not.) They cost from $20 to $50 from a variety of suppliers (MCM, Parts-Express, etc.)
Dec 29, 2016 | JVC Audio Players & Recorders
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
Can you connect a turntable to a denon receiver with no phono input?
Buy an external phono pre-amp and connect it to the AUX inputs on the back of the receiver.
May 25, 2014 | Yamaha RX-496 Receiver
The ground for the turntable connection is not working. I've got a bad hum with the ground wire attached to the screw on the receiver and a worse hum when I disconnect it. I had the turntable checked...
The ground connection on your receiver is simply connected to the metal chassis, so there's nothing that can go wrong with it. You won't have hum problems with any sources other than the turntable because their output levels are higher.
With nothing connected to the turntable input, do you still hear any hum? You shouldn't. If you do, the problem is not because of the ground connection, but because something in the receiver's phono preamplifier circuit is faulty. But if there's no hum, the turntable is responsible. The fault may be in the turntable's output cable. The shield connection may have broken loose from the terminal where it's connected in the turntable. Or your cartridge may be defective.
If your receiver is the culprit, you can see about having it serviced. Or you can purchase an external turntable preamp. Radio Shack sells one, and here's another source. With an external preamp, you can connect your turntable to one of the higher-level inputs (AUX, CD) and avoid the phono input.
Jan 12, 2011 | Yamaha RX-496 Receiver
I want to connect a phono turntable to my RX V550. any suggestions?
No can do without an intervening phono preamp.
Check out eBay for one or, if you still have an older stereo receiver with a Phono input hanging around, use it to preamplify the TT and run an RCA pair from the Tape Out to any available stereo input on your Yamaha.
Dec 26, 2009 | Yamaha RX-V550 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Yamaha rx v663 receiver, turntable input
Feb 10, 2009 | Yamaha RX-V463 Receiver
Jan 16, 2009 | Yamaha RX-V463 Receiver
- OPTiC
May 20, 2008 | Yamaha RX-V361 Home Theater Receiver
23 people viewed this question
 Grubhead
Grubhead
