Question about Head Toys
Cookie puppy we replaced battery not working.
We replaced new batteries in to cookie furreal friend puppy and not working. when i turn the switch to on it does bark, but when you try to pet its head it does not do nothing. is there a reset switch, or does it have to one of the springs being corroded? can i fix it?
listeur
  • 88 Answers
SOURCE: Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
Posted on Oct 28, 2007
toddq4
SOURCE: Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Posted on Dec 27, 2008
  • 12 Answers
SOURCE: 96 accord - turn key, nothing happens. bad ignition switch? help!
Could be.
Also the jiggling thing could be a coincidence. :0)
Tell me this.... when you turn the key, do you hear a CLICK?? If so your starter is probably bad.
:0)
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: furreal kitty white not working
Sounds like you need to reset it. If you need help finding the reset button, go to www.hasbro.com and click on Customer Service, then click on Instructions and find your toy to pull up the PDF file of the instructions. Hope that helps!
Posted on Aug 05, 2009
  • 5 Answers
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
Posted on Mar 08, 2010
How do I remove the batteries in my Furreal Friend Squawkers Mccaw Parrot?
There should be some srews where you can undo and remove the casing and then replace with new batteries try that
Jan 24, 2015 | Toys
REPLACED BATTERIES AND STILL DOES NOT WORK
There are a couple of reasons the pony may not work but more information would help. Did the pony word before you replaced the batteries? Some times if you get a new pony (new to you), the batteries in it are old and have corroded. Because the compartment is under the pony, you should probably check and see if the relays and contacts are in good, clean order or if there is corrosion on them. Coke will remove corrosion as will white vinegar. Use a Q-tip. If the contacts are all clean, then you need to check the wiring for a short. You may have to take the fur off to make sure that nothing is broken or touching something metal. Make sure the batteries are installed in the correct order and direction.
May 30, 2014 | Hasbro Furreal Friends Butterscotch Pony
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
I need a replacement battery holder for my furreal parrot
go to ebay they have them and thier prices are cheaper than in the stores or on other websites.
Sep 22, 2012 | Hasbro FurReal Friends Squawkers McCaw...
Furreal walk in' puppie won't walk
Sounds like either the batteries were not placed correctly or something got wet. Confirm the old batteries did not corrode leaving gunk on the ends of the connections. If they are clean, confirm you are putting them in the right positions. That's usually the issue. If not, you need to call Hasbro's Customer Service through this page
http://www.hasbro.com/customer-service/contacts/
Dec 31, 2011 | Hasbro Toys
I need a replacement battery compartment for my pony is there anywhere where one of these is available?
Call Hasbro's Customer Service and see if they can offer any suggestions. If they make any other FurReal friends that are so large that they require 6 D cells, then the box would probably fit. If they don't you'll have to do some internet searches for "Plastic On Off Battery Compartment" or see if HASBRO can tell you what the part number was and you can try searching for that. Hope that helps.
Dec 15, 2011 | Hasbro Furreal Friends Butterscotch Pony
Replacement battery holder
Hasbro doesn't even have FurReal ponies on their site anymore and emails don't get answered. I would call Hasbro directly from the following link and ask about the battery compartment.
http://www.hasbro.com/customer-service/phone-directory.cfm
Good luck :)
Nov 25, 2011 | Hasbro Furreal Friends Butterscotch Pony
Furreal chimp isnt only works when we shake it. something loose?
When any battery-operated toy seizes to work 3 checks solve 90% of the problems:
1) are the battery still firmly in place.
If not: secure them and try the toy again.
2) have the battery been replaced recently.
If not; replace and try the toy again.
3) Does the toy rattle (more than usual) when you shake it.
yes, it's really broken.
Some stores replace the toy if it's still fairly new, or a short letter/email to Hasbro stating how much your children enjoy the Furreal Friends Cuddle Chimp and how sad they are now that their new friend is "going away" could make a difference.
May 15, 2011 | Hasbro Furreal Friends Cuddle Chimp
FurReal dog stoped working even with new batteries
I noted some slight corrosion on one of the (spring) battery contacts. I used a Dremel tool to clean this up (some sandpaper on the eraser end of a pencil would also work). Inserted the new batteries and she has been resurrected!
Jan 03, 2011 | Tiger Electronics FurReal My Lovin' Pup
Toys Logo
Top Head Toys Experts
 Mikey
Mikey
Tom Chichester
Steve P
Steve P
Are you a Head Toy Expert? Answer questions, earn points and help others
