Question about Miscellaneous
To change a price on an order i placed that is now on deal of the day idon't have order number
Please get the correct model number (one posted here has too many numbers--label is on back of set)
GOOGLE THE MODEL NUMBER WITH THE WORD "LAMP" AND YOU WILL FIND (if available) the lamp and several places selling it.
Mar 23, 2012 | JVC HD-52Z575 52" HDTV
My service engine soon light stays on, I figured out that it's a Oxygen sensor. In the past colder months the light would come on for a couple days, then go off for a period of time. I am thinking the...
It should be close to the muffler. You can change it however the engine must be warmed up in order to remove the sensor. If you change it make sure you use anti seeing commpound when you replace the sensor. Prices vary from $15.00 to $100.00. Check with auto store for price. Might get a better deal on Ebay.
Jun 29, 2009 | 2005 Nissan Altima
I am after a diagram to help change clutch plates in yamaha yz125, cheers!!
Here's the deal. You get the diagram and I get a top rating on my answer. :)
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock.
Note that the first plate to go on is a fiber friction plate and the last plate is also a friction plate. A metal pressure plate goes inbetween each friction plate.
Please rate this solution. Thanks!
Jun 11, 2009 | Yamaha YZ 125 Motorcycles
I order 2 new yamata sewing machines last week
good luck, you will be on your own
Apr 20, 2009 | Yamata FY14U4AD
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Ordering CCU for kenmore elite 45986
Are you attempting to replace the Main Computer Microprocessor, or the User Interface? The Main Computer is located inside the washer behind the wash tub, while the User Interface is behind the control panel. The term CCU sometimes gets used interchangeably and I need to be sure.
It's easier to order parts directly from Just type in your model number (located around the door opening) and you will find both of the parts I mentioned under the "Control Panel" heading. If you wish to try a local Sears dealer in your area, you can use the part numbers provided by the Sears website.
I hope this helps you. Please post back if you need further assistance.
PS If you wish to compare pricing, you can also try Both sites get their parts from the same part source. They both offer comparible pricing with one or the other often having better deals.
Apr 21, 2008 | Kenmore Elite 45986 Front Load Washer
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
al simone
Level 1 Expert
Betty Kent
Betty Kent
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
