Question about Boss Car Audio & Video
Boss v30 has no picture threw any of the video outputs
Boss bv9555 says no bluetooth support
I'm afraid that you can only use a direct connect with this unit. The following are the specifications:
  • Compatible with Audio Output of iPod and other MP3 Players
  • Screen Size: 7
  • Touch Screen: YES
  • Adjustable: YES
  • Monitor: YES
  • FM: 18
  • AM: 12
  • Total Preset Stations: 30
  • Switchable Radio Regions: USA, EUROPE
  • RDS: YES
  • Remote: YES
  • Body Mounting: Double DIN
  • Motorized: YES
  • SD Card: YES
  • Audio RCA Output: 4
  • Video RCA Output: 2
  • Subwoofer RCA Output: 1
  • Audio RCA Input: 2
  • Video RCA Input: 1
  • CCD Camera Input: YES
  • Illuminated Controls: YES
  • Clock: YES
  • ESP: YES
  • Preset Equalizer: YES
  • ID3 Tag: YES
  • Last Position Memory: YES
  • Separate Bass and Treble: YES
  • Balance and Fader Control: YES
  • 1-bit D/A Convertor: YES
  • Loudness: YES
  • 8x Oversampling: YES
  • Total Power Output: 340 Watts
  • Local/Distant Switch: YES
  • Total Number of Channels: 4
  • Dimensions (H x L x W): 4" x 7.5" x 7"
Apr 22, 2012 | Boss BV9555 Car Video Player
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
___________________________________________
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
I have installed the v30 bose lifestyle system but I can not get any video output on my Samsung led tv. I have tried the hdmi cable and the component cable. It both doesn't work.please help me with this
I recommend you stick with component cabling.
Having no picture at all generally suggests the V30 is trying a video mode your TV does not support:
  1. video type (PAL or NTSC)
  2. Progressive scan
  3. an HD resolution beyond your TV's range.
I hope that helps.
May 21, 2010 | Bose Lifestyle 30 System
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
I cant get sound out of the Bose V30 and i lost the cable picture on Tv. What do i do?
I lost the video (HDMI) but can get all my sounds (TV, DVD, Radio, etc). HDMI cable is fine because it worke when plugged from cable box directly to the TV. Any suggestions?
Dec 22, 2009 | Bose Lifestyle V30 Home Theater System -...
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Nov 02, 2008 | Bose Lifestyle 30 System
Car Audio & Video Logo
41 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
