Question about Kenmore Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
  • Kenmore Master
  • 12,278 Answers
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Posted on Dec 20, 2016
Can I sew canvas with a thicker thread and do I need to replace the needle with a needle with a larger eye? Nathan's, trudy
It probably depends on what machine you are using. What is the make and model?
Have you tried anything yet? Does the machine struggle to make it through the canvas at all or does it jam when you use thicker thread?
Jun 10, 2015 | Sewing Machines
TENSION??
try a different needle, thicker thread different needle, see if that will
help
Aug 23, 2012 | Sewing Machines
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
Sewing a patch...what type of needle do I use
Always pick the needle type and size according to the fabric that you are sewing. I'm assuming if you are "patching" you might be using an iron on patch product on the underside of the garment and you should try to use a similar weight to the garment's fabric weight to do this.
If you are patching denim for example, you'd use a "denim" needle (teflon blue coating to slide through the fibres better) if you can, probably size 90 or 100. If you don't have a denim needle then just a regular 90 or 100 needle will suffice.
If sewing knits, use a ballpoint needle. For leather and vinyl use a Leather needle, these have a different shaped tip to piece the leather.
Try this link for more good general info on needles http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/ you might want to print out the section on sewing machine needle sizes and pin up in your sewing room.
My sewing needle selection is over 25 different needle packs and I probably buy 4-6 packs a year to ensure I've got the right size on hand. Change your needle for every new project - a needle stays sharp for about 4-6 sewing hours then should be replaced. If you are hearing squeaking or popping noises, your needle is blunt, chuck it.
In the words of my sewing mentor Wendy "Dont spoil the ship for a ha'pworth of tar" .
Mar 07, 2011 | Brother LS-2125 Mechanical Sewing Machine
Hi Can I sew plastic on 25 y.o. janome machine.
Plastic is easy to work on. Any needle will work, I'd go with a sharp not ball point. The stitch length should be a bit longer so you won't have the perforated effect and cut through the plastic. A thin size thread will cut the plastic vs a thicker one. Always try a sample first so you can adjust the tension specially if you can adjust it from the bobbin. GL
Jul 04, 2010 | Sewing Machines
I have a 12 sticher Kenmore maching that won't lay down the stiches? Everything is threaded but the thread won't go into the fabric
Check the needle, make sure it is not in backwards. Groove in the needle to the front. If you are sewing on a knit you may need a ball point needle/needle for knits.
Jul 25, 2009 | Kenmore 12102
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Juki MB-373 Button Attaching Machine
Use a thicker needle.
Release the looper screw and move it back and close to the needle, but without touching.
Tight the looper screw.
Adjust the needle through (left and right) wider.
Jun 07, 2008 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
