How do u change screen concast my changed where it is too light?
Samsung flat screen UA22EH5000 tv playing changing station screen blank only light at the back of the screen
Probably the the T con Board is faulty. T con board is the one which drives the pixels. If its faulty then you will not get the picture. the light at the screen shows that its back light is ok. hope you
have sound too. And if you are able to change the channel then is shows that the main board is also ok. But it can on;y confirm by changing the tcon board.
Sep 07, 2015 | Samsung Televison & Video
Lg inverter 2400btub..timer light 4blinks and returns to power light. This process repeated.
Change the inverter board if you are sure that the screen is ok . you can look for another tft lamp or led strip to test your inverter since u did not specify may be led or tft inverte ,if it light correctly then prepare to change your screen back light ,if not u change your inverter
Jun 26, 2015 | LG Televison & Video
Why the oil light came on and off, I had change the new pump,pick up screen, and change the oil sending unit ?
Most likely the oil pump light will come on if the oil pressure is low. This light is based on a pressure sensor. Your oil pump is likely not operating to deliver the required pressure. Check that your pump is installed properly.
Feb 01, 2015 | 2005 Dodge Durango
My screen will not light up on my acer. i changed
backlight is out.
If you changed the inverter and cable then the only thing left is the backlight itself.
HOWEVER, software does control this. If you disconnect the drive will you get anything different. - it will be operating on the BIOS only.
if it does reinstall the system, if not visit Best Buy
May 14, 2010 | Computers & Internet
Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
Jan 21, 2009 | Sylvania LC320SS8 32 in. LCD Television
Change Oil Soon light won't go off even after changing the oil.
You are able to reset it. The directions are in your manual:
1. press the options button under the screen utnil ENGINE OIL MONITOR appears on the DIC screen
2. Press the set/reset button to reset the system
The next screen indicates that the engine oil monitor system has been reset.
If the message is still on...try steps again
Jul 16, 2008 | 2006 Pontiac Grand Prix
Samsung dvd-vr 357 remote code for comcast
The HD cable remote --> Code 21075
May 16, 2008 | Televison & Video
I want to connect HD cable signal to HD projector
not directly unless it says hdtv somewhere or you need a converter box.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
