Question about Canon IR 4570 COPIER FOR 220 VOLTS ONLY
May I know how to solve it. IR4570 - Canon IR 4570 COPIER FOR 220 VOLTS ONLY
What means this code E000225-0001 ?
The light intensity of CIS is faulty.Disconnect and than connect flexible cable,if necessary replace it,or replace reader controllerPCB
Jul 11, 2015 | Canon ImageRunner 4570 | IR4570 |
IR4570 Paper Jam on Duplex
" Re: iR4570 Paper Jam on Duplex Mode
IR 2270, 0108 & 0207 jams your code is the fuser sensor but I would think about adjusting the loop esp if the paper is coming from an optional lower cassette.
FIRST THING I would do is replace the pads for the flapper figure 140 item 6 in parts manual. the two black foam pads were changed to a stronger white pad. These can cause your problem.
The updated pad number is fc9-4659 you need at least two . Plus you need to make sure the metal cover is on your registration sensor. fc7- 9370 ." http://www.copytechnet.com/forums/canon/68195-ir4570-paper-jam-duplex-mode.html
Oct 11, 2014 | Office Equipment & Supplies
Ir4570 email
Sorry, wxygzgc, but there is no indication at all in the Users' Manual that the IR4570 has any email capability.
http://www.agercopy.ro/poze/24547_1_Manual%20Utilizare%20IR%202270_2870_3570_4570.pdf
May 20, 2014 | Office Equipment & Supplies
Canon ir4570 ir3570 ir2870 ir2270 service manual
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Apr 12, 2014 | Canon imageRUNNER 2870 Copier
Error code ir4570
mohon tdibantu untuk mengatasi E0024-001 untu ir4570 terima kasih
Sep 18, 2013 | Canon Office Equipment & Supplies
Dpi scanner setting for canon ir4570 location?
For scanning doc.s it can changed in network scangeartool, for copier/ printer it was in copy/ print setting under user settings,
Jul 07, 2009 | Canon Office Equipment & Supplies
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
May 21, 2009 | Canon Office Equipment & Supplies
Canon IR 4570 COPIER FOR 220 VOLTS ONLY Logo
20 people viewed this question
old marine
old marine
