Catch up tv buffering how can I stop it - Televison & Video
Buffering when watching catch up tv how can I stop it
Get a faster internet connection or view it at a lower bit rate
download and watch at a later time when the whole file or enough has been downloaded to allow viewing without the buffer ring appearing before the end
Dec 20, 2016 | Computers & Internet
When playing doubledown it keeps spinning then re-connect
The "spinning" is BUFFERING due to a slow Internet connection, and it will be forced to re-connect if the buffer empties before the Internet connection can catch up.
May 11, 2015 | Dell Computers & Internet
How to stop buffering
If you are talking about the internet and a web movie that says that it is buffering, the major issue is your internet speed. Video streams to your computer and your player attempts to play it. When the feed is slower than the movie player, the play pauses to let the internet catch up and you get that error.
Apr 18, 2014 | Computers & Internet
I have an Acer 5542 laptop. Whenever I watch live streaming video, or YouTube, the video stops every few seconds for buffering to catch up. This is a fast Windows 7 computer with plenty of ram, clean...
The answer to this issue is your cpu, its a turion amd, basically it doesnt have the raw processing power required to render streams. there is no solution to this, other than replacing the laptop. AMD Turion II Ultra mobile processor M600 / 2.4 GHz just doesnt cut it, its not always about the clock speed, but how the unit processes data.
Sep 25, 2013 | Acer Aspire 5315 Notebook
I have toshiba satellite L500D. I cant download any movies or tv shows and when i watch tv from yahoo 7 it stops and starts as does Youtube....PLEASE HELP!!
When downloading videos from sites such as You Tube, the download is known as "streaming video". It fills the buffers on your machine and then displays it on your screen. If your connection is not fast enough, the buffers will empty before the data stream can re-fill them. This produces the stop start situation. The best way to overcome this is to do something else while the video plays, then come back when it's finished and replay it...it will now play ok.
If your connection is slow, then it's likey its timing out during the download of movies or TV shows, stopping the data flow.
Mar 19, 2010 | Toshiba Computers & Internet
My 50" plasma t.v. has a blue strip top to bottom that is always on the screen, what is the defect?
A solid blue line would imply that the lower buffer PCB has a loose connector or a bad buffer. Some plasma TV have these buffer ICs build right into the ribbon connector of the panel. At any rate, if you plan to have the TV repaired, STOP USING IT. Plasma panels are notorious for burn-in when viewing stationary images (station logos, video games, etc.). The blue line IS stationary and if you keep watching it, you will see the effects even after you correct the original problem.
Mar 15, 2010 | Samsung Televison & Video
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Cannot receive fax ...
Many fax machines have little internal buffer memory and the memory serves to receive a paket of signals which arrive faster than can be printed but when it is full, it may pause so the printing portion can catch up.
Check your manual for the phrase 'buffer memory' to see if they discuss why and when this might happen.
It's possible that the machine is still on line and has just paused waiting for the buffer to reduce its contents.
May 21, 2008 | Brother FAX-575 Plain Paper Thermal
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
