Question about Miscellaneous
Is it high?? How can I lower it - Miscellaneous
Is 170/70 considered high for a male age 81
an optimal blood pressure level is 120/80mmHg or lower, and high blood pressure is 140/90 mmHg or higher, whatever your age. The lower your blood pressure the lower your risk of heart attack, heart failure, stroke and kidney disease will be. For a blood pressure chart of readings
Blood Pressure Blood pressure chart
Sep 22, 2017 | Health & Beauty
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Minimum volume way to high
There may be a low/high switch which lowers or raises the base sound level before the volume control has any effect.
Mar 11, 2015 | Coby CX-CD248 Radio/Cassette/CD Boombox
545rfe oil level is too high,how to regulate
The oil LEVEL is too high, or the oil PRESSURE is too high?
To lower the oil level, just drain some off. Doing this will naturally lower the oil pressure, as well.
Feb 08, 2014 | Cars & Trucks
SW1 AC will only go on high or turn off, it won't turn on a lower setting. Help? what could it be?
What you mean is the blower motor will only run on high, right ?
It could be the fan switch or the resistor.
Jul 09, 2012 | Saturn Cars & Trucks
Is it possible to lower the top temperature on the thermostate. I can change the lower temp but not the max which I wish to set below the 180 level. Thanks
there is a high and a low limit on these units, the two control knobs are actually the reverse of what you are trying to accomblish,first lower the bottom or low cut off temp first then the high temp ,it must cycle a couple times for it to adjust
Jun 06, 2011 | Honeywell L4103A1019 combination aquastat....
A/c blower works, but only on high.
ITS THE SPEED RESISTENS THAT HAS BURNED,THE FAN HAS ONLY ONE SPEED , AND THE RESISTENS LOWER THE SPEED IN STEPS , GET A NEW ONE AND IT SHOULD WORK
Sep 26, 2010 | 2004 Pontiac Vibe
AC is stuck on high on my nissan titan 2006. I have heard it may be the resistor or the control panel
The blower resister is near the blower motor,mounted on the outside of the blower box,but actually goes inside the blower box.It~s function actually is to give the blower motor lower speeds.If it is only working on high,then this is the problem.If it works on high when you select a lower speed,then there is a high blower motor relay that is stuck in the closed position .Replace the relay.
Sep 09, 2009 | 2006 Nissan Titan
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
