Question about Norelco Health & Beauty
Is the battery replaceable on the SM-400 Ultra Groomer?
Ultra groomer sm400
I need to know how to reconnect the clipper blades together too!
Oct 23, 2016 | Sharper Image Ultra Groomer SM400 Beard...
Remington pg200 groomer disassembly
This is a very simple repair.
To disassemble, twist the round bottom part (with the battery contacts) counterclockwise just a bit. Use jaw pliers if it won't twist with your hands alone. To protect the plastic finish of the groomer use some duct tape or a rag on the jaws. Gently twist and open the assembly. When separating the bottom part, take care not to pull it apart too far from the main assembly to avoid damaging the 2 thin wires connecting the bottom plate on the inside of the bottom charger to the main body of the groomer. The batteries will just slide out easily; they are not soldered or attached in any way. You can replace the batteries with any two standard AAA rechargeable NiMH batteries (1.2 volt).
Since the batteries are so easy to access, and there is no solder involved, in a pinch you can even use regular AAA Alkaline batteries! (but, of course, NEVER USE THE CHARGER WITH NON-RECHARGEABLE BATTERIES!!)
The groomer is now as good as new!
Dec 08, 2012 | Remington Precision Deluxe PG-200 Beard...
Need blades and charger
Hi, I also have this groomer and I loved it, Used for a long time to trim my beard. I lost the 3mm blade but I have everything else, the blades, the charger, the trimmer of course and even the cleaning brush and the instructions manual. If you are interested let me know, I'm willing to let it go. My email is albertojquintero@yahoo.com
Feb 19, 2012 | Sharper Image Ultra Groomer SM400 Beard...
Dropped it and broke the "doubled-sided short
I'm looking for the 3mm trimmer, also called the Thinning Guide, If you were not able to fix your problem I will be happy to purchase this part. Thank you
Nov 07, 2011 | Sharper Image Ultra Groomer SM400 Beard...
I lost my charger can I use another charger
Oct 17, 2011 | Sharper Image Ultra Groomer SM400 Beard...
I have a Sharper Image Ultra Groomer SM400, I got it back in 1999. It has always worked flawlessly, but just recently I noticed that the connection to charge it either with the stand or staight from the...
Sep 24, 2011 | Sharper Image Ultra Groomer SM400 Beard...
Looking for replacement 3 and 6 mm trimmer attachment
I'm also looking for the 3mm trimmer, were you able to find it?.
Thank you
Sep 02, 2011 | Sharper Image Ultra Groomer SM400 Beard...
2005 DRZ 400 Will not electrically start
replace your "Tired" battery it is not putting out enough amps
May 05, 2009 | 2007 Suzuki DR-Z 400 SM
Health & Beauty Logo
47 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
