Question about Kitchen Ranges
I have a wolf Dual Fuel Oven DF-304-LP dual fuel stove. The oven turns on but it does not get hot in any mode.
When I put it in diagnostic mode I get ERR 10 1p r400 and the red light about the multi function light does not light in any cook mode. I have turned off the circuit breaker but still no heat. Why do these things always happen before a holiday! Any thoughts...
KOakaKO
  • 135 Answers
SOURCE: Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Posted on Aug 13, 2007
  • 23 Answers
SOURCE: GE Spectra range
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Posted on Feb 19, 2008
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
zazonker
  • 68 Answers
SOURCE: Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves 900DFa dual fuel cooker
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Stoves dual fuel cooker
if your qulified enough you need to bypass the timer electrically so as to put power direct to the oven
Nov 10, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
