Garden Logo
d
dave kessenich Posted on Dec 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is a Simplicity snow blower 38. it ran putting it away the day before. could not turn it over with pull cord or electric start. it acts like the gears/sprocket is locked up.
Dan Apthorp
Level 3:
  • Garden Master 2,824 Answers
  • Posted on Jan 06, 2017
Dan Apthorp
Garden Master
Level 3:
Answers
2824
Questions
0
Helped
888626
Points
7391
Mine did that and the next day mine was jammed with ice. Put it in a heated shop for a few hours and let it melt and dry out it is ok now. Water had got into the sprocket and froze.
I have a snapper snow blower model # LE3190E that will never start by the pull cord. But if I use the electric start it starts every time. Why does any one know
MIKE I HAVE THE SAME TYPE OF MODEL. YOU MAY HAVE TO PULL THE RECOIL FASTER FOR THE MOTOR TO START I HAVE THE SAME PROBLEM AS STARTING THE SNOWBLOWER
Feb 28, 2015 • Garden
1helpful
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
3answers
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
Electric start simplicity starter turned over for a couple of turns now won't turn over
Same thing happened to me.. I took off carburator and rebuilt it with a 20 Dollar seal and jet rebuild kit. i found all gaskets worn out. all tiny fuel inlets clogged....started first pull after and videos on rebuild on youtube make it too simple!
1helpful
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
1helpful
Ran over cord with snow thrower
Can you pull the engine over and then the cord locks or you can't pull the cord at all?
Dec 27, 2012 • Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
repeat if doesnt start
Top Garden Experts
Jay Finke
Jay Finke
john h
