Question about Remington Cycling
How do you install the rings on a Remington 1100 for light and heavy loads?
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
What year is my Remington 1100 Shot gun serial number M688425V
here is a website where you can look for your shotgun and the pics of the different years that it's been made
http://www.remingtonsociety.com/rsa/journals/1100
Oct 14, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
My remington 1100 will not cycle and its clean with 1 1/8 oz. shells
this shotgun has a gas blow back if you take off the barrel and pull out the blow back piston inside you should see two small gas ports clean them out with a steel pick to get out any carbon in them then clean the blow back piston and piston bore, dont over oil this part, but it must be realy clean and free to move look closly at the piston for any were in it if any gas is leaking past this piston the shotgun wont cycle unless you use realy fast and thumpy loads,
this make of shotgun never has liked light loads
Jan 06, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
Will not cycle
your shotgun may just need a realy good clean up,,,look in the gas by pass ports in the barrel are they blocked up with crud! clean the piston and cylinder remove all the carbon use very light oil on this part,,strip the action to clean it out of unburnt powder,,,,also they dont like soft rounds,,stick to fast heavy loads,,they love them,, but birds hate them!!!
Nov 15, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Disassemble a remington 11-87 super magnum
Go to the link below to get the manual. In the manual it will tell you how to disassemble the shotgun. It starts on page 14.
http://www.scribd.com/doc/12887293/Remington-1100-1187-Super-Mag-Auto-Shotguns
Good Luck
Nov 01, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Cycling Logo
Top Remington Cycling Experts
Vern Reece
Vern Reece
Level 1 Expert
Piyal Perera
Piyal Perera
raysaw
Are you a Remington Cycling Expert? Answer questions, earn points and help others
