Question about Sewing Machines
Eagle ea156 sewing mach threading pattern - Sewing Machines
akylas
  • 26 Answers
SOURCE: thread tension dial on riccar sewing mach. needs repaired
Please, tell me, is the main spintle, still on the machine, or it came off with the rest of the parts?
If you can put the tension parts, the one next to the other in front of the machine, and upload a photo for me, it will be very easy to explain how to put them back.
Posted on May 30, 2008
SOURCE: top thread wont pick up bottom thread
The XL-6562 users manual can be downloaded from Brother at:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_xl6562eus.html?reg=us&c=us&lang=en&prod=hf_xl6562eus
Posted on Sep 06, 2008
  • 13 Answers
SOURCE: hot to thread a bernina activa 240 sewing maching
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
  • 30 Answers
SOURCE: my material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Posted on Oct 28, 2009
sewinsnap
  • 135 Answers
SOURCE: Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Posted on Aug 14, 2010
How do you thread mach
you have only put,how do you thread mach?
so i think this is what you are asking.
try this link.
How to Thread Sewing Machine
Dec 16, 2016 | Sewing Machines
I NEED A FOOT FOR THIS MODEL SEWING MACHING
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? c
May 21, 2015 | Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Machine keeps saying recheck/rethread upper thread
sounds like the computer motherboard could have malfunctioned
and needs to be checked
Nov 21, 2012 | Brother InnovIs 4000D Computerized Sewing...
How to thread janome 664 sewing maching
janome customer service
sewusa.com
sew4less.com
sewingpartsonline.com
youtube
ehow
Apr 13, 2012 | Janome Sewing Machines
How to thread an necchi sewing maching
try sewusa.com they have threading diagrams
Nov 24, 2010 | Necchi 3610 Sewing Machine
The thread on Singer sewing maching is not locking with the bobbin thread; it is just straight.
You may need to retime the machine, email me and I will attach instructions drivewithken@blueyonder.co.uk
Aug 10, 2010 | Singer 8280 Mechanical Sewing Machine
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Bobbin problem
upper threading/tension is wrong
Jun 30, 2009 | Sew D'Lite SM-888 Mechanical Sewing...
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
