Question about GE Kitchen Ranges
I have Range GE J34CFT 1 that is not heating up correctly
I have Range GE J34CFT 1 that is not heating up properly. When I turn the oven up to 425 the lower is glowing red and appears to be fine. When set the oven on broil the upper element appears to be fine. When set the oven at 350 there is heat however it doesn't seem to correct. When cook something it taking much loonger then it should...Any assistance would be greatly appreciated...Thank you in advance...David
    President:
  • 1,865 Answers
You have to start with putting an oven thermometer in the oven and comparing the oven temp with the temp that you set it to
Posted on Jul 21, 2009
Ge model jb400d oven will not heat up
Troubleshooting Why Your Gas Oven Won't Ignite or Heat ...
? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
Gas Oven Won't Heat - How to Repair (Part 1 of 2 ... - YouTube
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
GE, Hotpoint & RCA - Wall Oven Diagnostic - Not heating ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Dec 30, 2015 | GE Kitchen Ranges
I have a GE Range that has started acting up. it was working fine at 350, i had to have a temp of 425 and the temp went soaring to broil. the oven control knob would not turn the oven off, i had to pull...
Yes, most likely the broil relay got welded shut. The company will want to sell you a whole new control board for about $200.00 -- but if you have any soldering skills, you can purchase a new replay for around $6.50.
Feb 17, 2018 | GE JGBS20 Gas Kitchen Range
My oven won't heat up.
This is usually because the igniter is not getting the proper amp draw to open the gas for the bake burner. To check the igniter for the correct amp draw watch the video on troubleshooting a gas oven.
www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
Head a popping sound and oven temperature doesn't work
Most likely a bad element. Turn off the power to the oven. Remove the racks. Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes. Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad. A new element will correct your problem. If the element reads as good you have a wiring problem or a bad control.
Jan 04, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
Jul 20, 2009 | GE Spectra JBP84 Electric Kitchen Range
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not turn off
it sounds like the pilot could be restricted and not heating the thermocouple completley,or the t-couple is weak.is there ant drafts hitting the oven?
Aug 02, 2007 | GE JGBP28SEHSS Gas Kitchen Range
Kitchen Ranges Logo
200 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
