Question about Crafts & Hobbies
This is about a Holiday ExprThe engine will run 2/3 of the way around the track and stop. I have cleaned track and wheels with alcohol.I notice that the contacs seem wore down. Can they be purchased?
5 Suggested Answers
  • 653 Answers
SOURCE: Life Like train hesitates and stops altogether.
It sounds like you have eliminated the motor as the problem. Try cleaning all of the electrical contacts including the connections between rail sections and the hot rail with fine steel wool (make sure you clean up all of the remaining steel wool bits since they are conductive). If that doesn't work, look at the transformer output.
Posted on Mar 05, 2009
  • 1985 Answers
SOURCE: serpentine belt blew due to belt wheel sheering off
with the belt off,try to spin each and every pulley,and water pump,alternator,idler pulley,automatic belt tensioner pulley,sounds like one froze up and took the belt out.
Posted on Dec 10, 2009
  • 4369 Answers
SOURCE: hello I recently purchased the newbright 384
You should have a transformer with 110 volts ac (household voltage) going in. Coming out should be low voltage dc (direct current) varing from zero to about 15 volts dc. You can measure it with a voltmeter set on dc volts and a 20 volt scale. See if you get voltage out when you turn up the speed of the train - dial. You can test with a 12 volt parking lamp from the auto store or Kmart.
Check for a rest buton on the transformer and also read the transformer and owner manual for the voltage specs. Good luck
Posted on Nov 30, 2010
SOURCE: IRobot rumba 4000 seems to run ok and then starts
It sounds like your Roomba's brush gears are not working. Run the robot without the dust bin to see if the brushes are turning. If they are not, the robot will need to be replaced. Contact iRobot CS for support at (877) 855-8593.
Posted on Dec 06, 2010
Bachmann Emily
check all track connectors(squeeze lose ones with a needle nosed pliers..check wire from transformer to the track..and during assembly, the track gets any dust on it, the wheels wont make proper contact for the engine to run..) as for the locomotive.. sometimes you can clean the motor brush comutator with a simple pencils' erasure by rotating the motor armature by hand(small as it is) to clean the pickups on will better help to transferr the electric into the motor..sometimes on these track layouts, you need fine grit sandpaper to run across the top of the rails as the manufaturer puts a protective coating on these.. it wont carry power to your can also use the backside of a butterknife drug around the layout a few times with the electric off.. it helps you feel any rough spots on the track/layout..
Mar 08, 2014 | Bachmann Thomas Tank Emily's HO Train
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
I have power to the train and it runs but it moves extremely slowly and sommetimes comes to a stop.
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
Dec 19, 2010 | New Bright 384 Holiday Express Animated...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Nov 28, 2010 | Lionel 11000 Holiday Tradition Express...
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
No power to track and/or train. Power to Holiday Express Train
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
Nov 27, 2009 | New Bright 384 Holiday Express Animated...
Cannot turn off the machine
Try cleaning the laser with a cleaning cd.
May 20, 2009 | Sony D-NE20 Personal CD Player
Crafts & Hobbies Logo
96 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
