Question about Vizio Televison & Video
How do you set which input a vizio tv starts up on?
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ... > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
How do I repair my Vizio tv?
I would check what the input is set on .
Mar 02, 2015 | Vizio VA19LHDTV10T 19 in. LCD TV
Trying to hook up my Vizio vbr334 to my Vizio tv I keep getting a no signal why
The television is probably set to a different input source than your device is connected to. Try setting the input to something different. The names of the inputs are usually written on them (molded into the plastic).
Mar 29, 2013 | Vizio VBR334 3D BluRay Disc Player 1080p...
How to restart set up wizard on my vizio e420vl..i accidentally inputed cablle as the tv input..and now it won't let me input anything else..i don't have cable..just want to pick up regualr tv channels
Go into tv menu goto SETUP go down to Ch.setup enter to pick AIR not CABLE and press enter for scanning for regular Free AIR tv broadcasting channels.
Mar 25, 2011 | Vizio 42 in. LCD TV
I have a 37" vizio. I was switching input form tv
Press the input button and the set will turn on. Keep pressing the input button until the correct input is selected.
Nov 03, 2010 | Vizio VW37L 37 in. LCD HDTV
Vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Oct 31, 2009 | Vizio VL320M 32 in. HDTV LCD TV
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
21 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
