Question about Sunbeam Heating & Cooling
Sunbeam heated mattress pad is not working when you turn it on it will just blink F2. I have tried unplugging waiting a while and re plugging but it still just blinks F2. Any idea how to fix?
SOURCE: new heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
Posted on Nov 28, 2009
SOURCE: malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Posted on Dec 13, 2009
SOURCE: F2 Fault Code On Heating Pad
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Posted on Feb 02, 2010
SOURCE: why does the light blink on my westpoint stevens
http://martex.com/page/view/id/581
http://www.mambomedia.com/CLIENTS/WPH/WPH_Trouble_Shooting_Guide-1.2.pdf
Posted on Apr 24, 2010
SOURCE: Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Posted on Sep 28, 2010
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
Mar 05, 2014 | Sunbeam California King Arlington Heated...
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Binking light on one control of electric blanket (Sunbeam)
I'm not sure how I was registered as having a problem with an electric range; my problem was with my Sunbeam electric mattress pad.
I used one of the suggestions I read here. I unplugged the connection to the mattress pad and blew into the receptacle to clear any dust or lint from it. I reconnected everything, plugged it in, and the problem has been eliminated.
Thanks for the suggestion.
Oct 05, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I just moved to New Zealand
It seems like the AC converter may not have the ability to procduce enough current. Check the wattage of the heat pad then see how many watts the converter can produce. (watts = volts x amps). You can buy a good Sunbeam electric blanket in NZ for about $110NZ, a capable AC converter may cost you considably more. Enjoy your stay in NZ!
Jun 19, 2009 | Sunbeam SG7621SP Grill
New heated mattress pad won't warm up. Controls keep blinking.
Dec 13, 2008 | Sunbeam SG7621SP Grill
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
The controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Oct 07, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Malfunction heating pad
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
