Question about Jandy Aqualink Rs4 One Touch Control System Control System
Filter clicks, but won't turn on. Pool lights
Filter clicks, but won't turn on. Pool lights work, so does spa blower. Spa won't turn on. Wall unit diagnostic menu says that solar switch is "open," but I don't have solar heated pool. I'm guessing it's a fuse as pool is only two months old? Where do I get a fuse, and how do I replace it? Regards, kg.
  • 139 Answers
Put your aqualink into service mode. then select components manually this will override any pre-programmed options
Posted on Jul 21, 2009
When I turn on my blower for spa ( connected to pool ) it blows dirt into spa
blowers for spa units are basically a vacuum cleaner motor in reverse
that means that instead of operating like a vacuum cleaner the suction end /hose is under the spa pool and so any dirt , dust , vermin etc will get sucked in and be blown along with the air , into the pool
there is no air filter at that end of the unit to stop ingress of material but if there is , check /treplace that filter
Jun 14, 2017 | Pool & Spa
Sofina portable spa
there is a pressure switch and it may be the problem, its usually next to the heater with 2 wires, it might just need a light tap with a screwdriver handle (LIGHT)... the spa must be full of water
Sep 26, 2013 | Pool & Spa
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Polaris 280 pool cleaner won't suck uP debris into bag
if pressure ok at wall and filter is clean check inside unit to see if hoses came off put on and zip tie
Mar 19, 2013 | Polaris 280 In - Ground Pool Cleaner with...
We have an Jandy Ji8000. We have really enjoyed having it for years. Just lately, the filter goes on at the wrong time. If we try to turn it off at the panel in the house, it will not turn off. We have to...
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
Mar 24, 2017 | Jandy AQUALINK RS TELELINK KIT
I have a pool with a built in spa and I need to Isolate the spa from the rest of the pool. So I can heat it and not the whole pool. I don't know how to add pics so I will describe the best I can. I have 2...
the actuator at the intake of the pump divides spa intake and the pool intakesmake sure switch on actuator is on 1 or 2 if in pool mode the off should be at spa intake the out inpool postition the off should be to the spa outlet
Feb 18, 2011 | Jandy Pool & Spa
Blown Heater blower motor
you will have to replace the brain unit its shorted out
Jan 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
308 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
