Question about Sewing Machines
Install sewing neddle eagle 156 - Sewing Machines
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Kenmore Sewing Machines
Neddle is hitting the strike plate?
sounds like the machine is out of time & needs to be taken to a sewing machine repair shop for repair
Feb 20, 2012 | Brother SE-270D Computerized Sewing...
I put in new needle an try to sew but the neddle hits the shuttle hook an bens the needle what to do
I'd say that the timing is out; this is generally a job for a sewing machine technician
Mar 09, 2011 | Kenmore 15718
What class of bobbins does this machine take. I'm having trouble finding ones that fit properly LS-2125i
SA 156 or Singer 15 class. SA 156 metal (they work better anyway)you can get them on ebay 20 for $8.99 and free shipping,
Aug 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
What size neddle do i use in a 90-1260 dx machine
It depends on what weight fabric you're sewing as needles come in standard sizes. Read my tip about types of needles for help.
Jul 20, 2010 | Euro-Pro 1260DX Mechanical Sewing Machine
Neddle problem
Sounds like the needle is hitting the bobbin casing. Take it out and re-seat it. Check your manual.
Aug 11, 2009 | Necchi 3537 Mechanical Sewing Machine
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Needle doesn't connect with bobbin
hello there, do you mean you can't hooked up the lower bobbin thread to neddle bobbin thread, all you gonna do is to check the bobbin winding thread if it is in clockwise rotation when you pull out on the bobbins casing, insert the shattle casing, then manually rotate by your hand try to hooked up the bobbin thread by your neddle thread. let me know if you got it
regards.. rated me thanks
Mar 31, 2009 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
