Question about Lands Phones
The ringer doesn't work for incoming calls - Lands Phones
pazman
  • 81 Answers
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Posted on Mar 30, 2008
  • 149 Answers
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
SOURCE: Ringer doesnt work Nokia 3120
Have just fixed this problem on my 3120 everything else was working on it except this. If you take apart the phone starting with removing battery, then the face plate and touchpad, then using a T6 screwdriver remove the 6 screws holding motherboard to the chassis and remove motherboard. Then remove silver metal base plate to expose the Antenna Assembly, very gently remove this part as this is where the ringer is. When you are looking at this you will see two little spring loaded balls on the left hand side, you should be able to put your finger on one of these to get a clicking sound. Both of these should be in the up position if not do this, with a very thin blade gently go into the seam nearest the spring loaded balls and cutting thru the glue go along edge of seam until they pop up. Then put it all back together again and hopefully this has sovled your problem. My phone was out of warranty and i had 3 quotes of $70-$90 to fix so i had nothing to loseby doing this.
Posted on Jan 16, 2009
  • 63 Answers
SOURCE: Turn the ringer on for external calls.
in system programming
Posted on Mar 14, 2009
consultel1
  • 860 Answers
SOURCE: phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Mar 26, 2009
How do i download a free alcatel ringtone for incoming calls
Do you have the ringer volume turned all the way down which is to say you hear no ring, check that first, if the ringer volume is turned up then the phone is defective and needs to be repaired or replaced depending on cost.
Mar 16, 2017 | Alcatel Cell Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
My NEC phone Doesn?t ring on incoming calls i need to program it but i don't know how, please help.
frist u check your profile setting
secound u change ring
& now check supply of ringer & change ringer Ic
Mar 17, 2009 | Lands Phones
Ringer does not work on incoming calls
If someone is calling, do you see it on the phone? If so, you may have muted the sound. Try looking for a a button with a music note on the phone. Hold that button for a bit(atleast that's how it works on my phone)
Feb 24, 2009 | Uniden 2.4 GHz Expandable Phone System...
T305 ringer not working
Check your phone settings for the ringer. Is it on? Is it on vibrate?
Aug 01, 2008 | Motorola Mobility Bluetooth Hands-Free...
When a call comes in the ringer doesn"t ring
Jun 16, 2008 | NEC DTU 8D-2 Corded Phone
No ringer for incoming call
Mar 30, 2008 | Panasonic KX-TG6052B Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
