Question about Sport & Outdoor - Others
How to install needle eagle 156 - Sport & Outdoor - Others
My Webcam Model 156 does not work on my computer. I also don't have a webcam software. what shall I do ?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 16, 2012 | PC Concepts 300K Webcam
VETERAN...I want to install an EAGLE on my Tahoe trucks hood but the front of the hood faces downward making it impossible to keep the eagle straight. what do you suggest?
Right where you want to install the eagle straighten the the front in other word staighten the foundation where the eagle will sit at.
Jun 05, 2011 | Chevrolet Tahoe Cars & Trucks
Alfa 156 mis-firing
Hi i had the same prob with my 99 alfa 156. It seems that there could be a problem with the air sensor on the induction kit. If you remove the sensor and use some brake cleaner to clean it. Use gloves on dnt touch the sensor its self, and dnt use a rag or a cloth on it. Install it again after 5 or 10 mins and start the car up. It should work fine. If it does the trick check your air filter as it might be damaged and not working properly. I checked mine and found there was no filter in it at all. I found a cone filter works better for the car.
Jul 06, 2010 | 2000 Alfa Romeo 156
Blocked washer jet alfa 156
You will probably find there is one or two plastic clips on the washer jet. You can usually get at these from the under side of the bonnet. Be carefull not to force them though because they do get brittle over time. If you do break them you can buy new ones from Alfa or a good motor parts store will probably have universal ones at a fraction of the dealer cost.
Jan 13, 2009 | 2000 Alfa Romeo 156
Sport & Outdoor - Others Logo
106 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
