Question about Sewing Machines
How to thread 156 eagle sewing mach
How to install needle eagle 156 sewing mach
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
louislevel_2
  • 374 Answers
SOURCE: Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Posted on Mar 07, 2009
  • 323 Answers
SOURCE: consew 230 sewing machine...will not pick up bobber thread
needle should be 16x257 Industrial machine needle with no flat side.
It does have a long groove on one side and a scallop just above the eye of the needle on the other side. On this machine the needle is inserted so that the long groove goes to the left and it threads left to right.
The thread breakage may be caused by a rough place on the hook. You need to turn the machine on it's back and look and feel all the way around the hook assembly. If you find a rough spot it can be removed with an emery stick. If it's not a rough spot, then the machine is probably out of time.
sewman7
Posted on Mar 20, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
My white 1800 jeans machine sewing maching is working but not stitching.
So the top thread is not picking up the bobbin thread? Try a brand new needle. If that doesn't work, then the machine is probably knocked out of time. Search for sewing machine timing or take it for service.
Mar 24, 2018 | Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
New Home sewing maching, using Gutermann thread to sew faced, turned "windows" (square)....PROBLEM: the machine checks, the thread pulls, seriously nests on the underside and I notice that the thread...
1.put new spool of thread on
2.watch the thread on the take up lever,make sure it doesn't come off
3.check the tension disk for loose threads, if there are threads pull out
4.check needle for being bent or blunt --if so replace
Jul 29, 2010 | New Home HF-1012 Mechanical Sewing Machine
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Kenmore 15358
I have a 12 sticher Kenmore maching that won't lay down the stiches? Everything is threaded but the thread won't go into the fabric
Check the needle, make sure it is not in backwards. Groove in the needle to the front. If you are sewing on a knit you may need a ball point needle/needle for knits.
Jul 25, 2009 | Kenmore 12102
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
