Question about Tablets & eReaders
How do I prevent my yoga tablet freezing?
Tablet froze for the second time I corrected this and I would like to know how to prevent this hapnine again
Rca 7 inch tablet
unfreeze it and start again
I had a freeze occur on an ipad air after trying a reset and the method for that was to hold down the button at the bottom of the screen and the button at the top side of the pad at the same time for around 20 seconds
the bottom button turns of the screen as does the side top button but when pressed together and held for a time it reboots the unit
if it is not the same the do what I did
go google on another computer and type in ---how to unfreeze 7" rca tablet --- and read forums and other sites that may give you a clue as to how to do it
Jun 25, 2016 | Tablets & eReaders
Lenovo Yoga tablet, issues
ram booster app download install clean now fast to fast tabelet daily one time on and off your tab
Jan 23, 2016 | Lenovo Yoga Tablet 10
My Lenono Yoga 10 tablet froze when I switched it on. What can i d to unfreeze it?
Try using a paper clip in the reset hole. If not you need to do a hard reset that will remove all apps and data you added. Watch this: Remove Forgotten PASSCODE PASSWORD Unlock For ALL Android Devices...
Nov 14, 2014 | Tablets & eReaders
Tablet froze up
if your tablet freezes, or in any other way does not react, you can force it to turn off by pushing and holding the power button for 15 seconds.
If this doesn't work, use the 'pinhole reset button' when available. Get a paperclip and use it to gently push the reset button on the backside of the unit.
Oct 27, 2014 | Tablets & eReaders
How to reset factory settings
On your tablet, tap on Settings > Personal > Security. The reset to factory settings option will be near the bottom.
Reference: Lenovo Yoga Tablet 10 User Guide.
https://www.cellphones.ca/upload/manuals/lenovo-yoga-tablet-10-manual.pdf
Hope this helps!
Aug 25, 2014 | Lenovo Yoga Tablet 10
Galaxey 2 tablet freezes
Press and hold the power button for 10-15 seconds. This should hard reset the tablet.
Dec 08, 2012 | Samsung Galaxy Tab Tablet PC
Samsung galaxy tablet is frozen and the power would not turn off. What should I do ?
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
Apr 05, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
How to unfreeze kindle screen? my kindle screen has froze
Hey
Well there are a lot of reasons why the Kindle screen freeze.
most of the times it happens when the Kindle is trying to upload some big files like photos, movies, flash etc. in this case all you have to do it to wait and it will un-freeze in couple of seconds.
Another Very common is that the Kindle Memory is full and he can't respond until some of the memory gets free, this usually will happen once you click too many times on the screen, the poor Kindle is overwhelmed with orders and doesn't know what to do, this happens to "newbies" with the kindle.
A lot of these freezing problems can be fixed by resting your Kindle, you can do a Soft reset press the Alt-Shift-R keys at the same time. (Shift is the one that looks like an up arrow.) If that doesn't work, plug your Kindle into the charger and try again.
You can also do a Hard Reset take the cover off the back and insert a paperclip in the little hole. Hold for 10 seconds, you may need to try again with the Kindle plugged into the cradle.
For the Kindle DX Hold the top on/off switch sliding it to the left and keep to the left, hold for 60-80 Sec, Release it. Wait a minute - the DX will flash. Then the screen will go black and then the main Kindle screen (the guy sitting under the tree) will appear and the start up thermometer bar. Once that's completed, the main menu will come on, and your books will be rstored in batches over the next couple of minutes
And of course you can always Call Amazon Customer Service at 1-866-321-8851, 6a-10p PST, 7 days a week
Hope this will be helpful
Uri_K
Feb 04, 2010 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
20 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
