Question about Jenn-Air JSD2789GES Side by Side Refrigerator
I PUT IN A NEW CONTROL BOARD, I WAS TOLD I NEED TO RESET IT.
    President:
  • 2,187 Answers
You just need to have the fridge stay unplugged overnight to have all the fluids settle and to have the all sensors clear out, including the board.
Posted on Jul 21, 2009
Need reset sequence
o reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls.
Apr 18, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
GeErefrigerator. Model LHSF6LGZBCBB How to reset the refrigerator I for the first and only time used the control lock button and now it will not unlock. I have unplugged the refrigerator and that still...
The manual says to hold the control lock button down for 3~5 sec to unlock the board. To remove the board, the bezel pops off from around the control. Once removed you can easily access the screws to remove the board.
Dec 10, 2013 | Washing Machines
Need help with blank TV screen after replacement of control panel
The new board may be causing this--either defective or the set needs a reset of some type---get the board from Samsung or where?
Jun 15, 2012 | Samsung LN40A500 LCD TV
I have a GE refrigerator model # GSL25JFPABS. I have been told that the main control board WR55X10656 has been "replaced" by # WR55X10942 now. However I found a 656 board pretty cheap locally and...
WR55X10942 is the board that goes into that machine,it's the most up to date board out there,why would you put a first generation board in there that you know is gonna fail when they upgraded it to the WR55X10942 and that's the board it calls for now so don't put the other board in there
Apr 19, 2011 | GE Refrigerators
I have a KitchenAid model YKGSC 308LS0 with a display messagw F2:E1.Iwas told by a previous expert to turn off the power for a few minutes and it might reset. If it didn't I would have to buy a new control...
Here is the code fault you have:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 16, 2009 | Kitchen Ranges
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
48 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
