Question about Home
Not heating up showing FF on both control remote
What is FF code, my sunbeam electric blanket is not warming up, unplugged and replugged several times, none
    Top Expert:
  • Home Master
  • 44,161 Answers
The FF may be an indication that the heating element has failed.
Posted on Dec 20, 2016
My sunbeam heating pad model cat95c is flashing f
unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
Mar 15, 2018 | Sunbeam Heating & Cooling
I have a sunbeam electric blanket and a code of f-2 keeps coming on. Is the blanket bad
1.) Follow the instructions on the flag tag attached to the control cord to reset control.
2.) Check the blanket/mattress pad for visual damage.
3.) If no visual damage is found, unplug the system from wall outlet.
4.) Check that the control is well-connected to the module.
5.) Plug the power cord into the wall outlet.
6.) Set the control to "On".
7.) If the system does not operate after 2 or 3 times trying to reset, disconnect the power cord and contact Sunbeam Consumer Care.
Nov 01, 2017 | Sunbeam Heating & Cooling
Our dual control Sunbeam electric blanket is 3 months old and is not heating up, however the powere is on both controls
Should have warranty, plug and unplug the connection to blanket several times. if no help call their customer service. You may be able to return it to the store you bought it from and get a replacement. Hopefully, you still have receipt.
Feb 28, 2015 | Sunbeam Electric Blanket Dual-Controller -...
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
Mar 05, 2014 | Sunbeam California King Arlington Heated...
Dual control electric blanket doesn't get warm, the controllers just blink
The problem can be caused by a defective heating element in the blanket.
Nov 24, 2013 | Sunbeam Electric Blanket Dual Controller...
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
Sunbeam electric blanket flashing ff when I try to turn it on.
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
Dec 11, 2008 | Heating & Cooling
Electric blanket error code
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Mar 25, 2008 | Heating & Cooling
Home Logo
88 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
