Question about The Watches
How do i get to fix my husband the luxurman watch it's broken
Where do I get the band pins for an luxurman watch
Any watch shop should be able to sell you replacement pins
Oct 01, 2017 | The Watches
I need a glass replacement for my husband watch where can i go to get it fixed please ?
Take the watch to a local jeweler to have the crystal replaced
Dec 03, 2015 | Watches
I bought my husband a Kenneth Cole Reaction watch with a black rubber band Code:NC1398 c275-47. The rubber band needs replacing because it is broken. Would you please know where I can order a new band for...
Try looking for a local Fast Fix jewelery repair.
They're in most malls nation wide,they will have one right in the store plus they do repairs for a nominal fee.
Hope this helps you a vote would be nice,Gary
Dec 01, 2010 | Kenneth Cole KC1104 Wrist Watch
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
Good luck.
Aug 21, 2010 | Bulova Watch
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    My husband got a fossil watch for a 15 year service from his place of employment, one of the stems (pin) came out of the band and I am trying to locate one to fix the band. thanks
    the best thing to do is the next time you go to the mall take it and ask one of the people in those little watch booths if they have one that'd fit. they shouldn't even charge you.
    Aug 04, 2010 | Fossil AU4003 Wristwatch
    My husbands watch broke at the buckle. The pin is missing and we can not find anywhere that has a big enough pin to fix the watch.
    You need to measure the gap on the buckle to know how large of a pin you need. Usually in millimeters. A jeweler should be able to fix this with no problem. You can also go to Walmart and find a cheap watch that has the same size buckle and scavenge the pin from that buckle. Take your old buckle with you to make sure it is around the same size.
    Dec 01, 2008 | Fossil Watches
    Watches Logo
    29 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    Are you a The Watch Expert? Answer questions, earn points and help others
