Question about Garden
My simplicity locked up and I can not turn it over with the pull cord or electric start. I can not move it at all.
  • 22 Answers
Is there oil in engine. If not may have seized. Removed spark plug and see if turns over. Have seen some fill with water through exhaust. If has water flush out and should start.
Posted on Dec 28, 2016
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
It is a Simplicity snow blower 38. it ran putting it away the day before. could not turn it over with pull cord or electric start. it acts like the gears/sprocket is locked up.
Mine did that and the next day mine was jammed with ice. Put it in a heated shop for a few hours and let it melt and dry out it is ok now. Water had got into the sprocket and froze.
Dec 20, 2016 | Garden
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Why won't Toro start - we have electric start and pull cord won't move?
pull on the bail handle tape it down try to turn blade by hand with plug removed if you can move poure a little oil end cylider and spin it sevseal times put plug back in start it i think it heat siezed check oil level to thats what us red necks do let me know
Aug 27, 2014 | Garden
Snowblower starting problems
It is still jammed disasewmble if necessary.
Dec 17, 2013 | Garden
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Feb 16, 2010 | Simplicity Vacuums
Readoout says
1. Turn machine OFF and unplug electrical cord from wall or power strip.
2. Turn ON printer without the power cord plugged in (this will discharge the power capaciter in the printer).
3. Plug electrical power back in and turn on printer...
4. It should have reset.
Another possibility:
The scanner arm has the physical "lock" switch in the locked possition. Turn OFF printer and move the switch to the unlock position. Turn on printer.
This switch is for whenever the printer is moved to a different location and will protect the scanning bar.
Hope this helps!
Sep 09, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
May 23, 2009 | Garden
Sweeper-mulcher starter cord won't move
yes it the locking problem for sure.calling a tech is much advisable.
Nov 09, 2008 | Craftsman Garden
Garden Logo
816 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
