Put new battery in still get no signal from monitor
When turn on computer there is a sound signal from computer but the monitor has no picture but monitor is okey.
This sounds like a dead motherboard.
you should reset the cmos (using a jumper) or remove all power cords, battery and the cmos battery. wait 10 mins and put everything back.
The second option is a dead power supply. The only way to check that is to replace it with a new one.
Aug 23, 2014 | Computers & Internet
Battery change, now no signal
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
May 24, 2010 | Garmin Forerunner 305 GPS Receiver
No signal on monitor
try resetting the bios on the motherboard. The bios jumper is usually located near the battery(CMOS battery). If you can't find the CMOS jumper, just try to remove the CMOS battery and put it back again. This will reset everthing.
Mar 28, 2010 | Gateway GT5622 PC Desktop
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
No image on onitor dell desktop -
if you have no image on the monitor when you hook monitor to other pc and you installed the video drivers for monitor and still no image then you got either a bad power cable for your monitor or your monitor is shot...get a new monitor... try testing again with a different power cable... if still the same... then monitor is shot... replace it...
Dec 22, 2009 | Dell Dimension 3100 PC Desktop
No monitor signal
make sure pc is off ,make sure video card is seated properly if it is try resetting cmos there is 3-pin jumper ususlly by battery and usually says reset cmos by it I have seen many differences according to mobo this can also be accomplished by taking out the mobo battery (the little round silver battery) if you have jumper take off 2 pins its on know put on other 2 for 1min then put back turn on, if removing battery take out then turn on pc
May 16, 2009 | Computers & Internet
Vector Sec says they got low batt signal from my home system
Open your alarm cabinet, inside is a battery. Replace it with the same sized battery. it is probably a 12V 7ah battery. You should be able to find one for less than $30 locally.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
No Video Signal
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Oct 24, 2008 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Digital video stopped working
did you try to set the out put on the monitor to dvi on the display settings? in windows
Jan 05, 2007 | Dell UltraSharp 1907FP 19" LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
