Question about Panasonic Viera Tc-p65st30 65" Full 3d 1080p Hd Plasma Internet Tv
On panasonic plasma TC-P65ST30 with wrong suffix A-Board. Will the A board cause 6 blink code?
    Top Expert:
  • Panasonic Master
  • 74,666 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Jun 09, 2017
Slinteriors
  • 8617 Answers
SOURCE: no picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Posted on Jun 02, 2012
gopakumarg43
  • 74666 Answers
SOURCE: What is causing a 6 inch vertical black bar on left side (only) of panasonic TC-P65ST30
The X-Sustain board has the fault I presume. Just visit this site, named 'Electro-help'. This type of fault, and its repair proceedings are detailed there with illustrations. Check this link and select the site. Pull up older posts there. Sometimes, ads attached with each posts there might give you details of the components availability too.
Posted on Jul 19, 2012
gopakumarg43
  • 74666 Answers
SOURCE: I need help changed power supply board and ss board and still no picture it is a model TC-42PX14 panasonic the red light still blinks seven times. At wit s end isn't much, can you help me.t
Check this link and select the site named 'Electro-help' You can get more details about the fault to your TV, with 7 blinks of standby light. Check this link and select the site named above.
Posted on Jul 28, 2012
gopakumarg43
  • 74666 Answers
SOURCE: My Panasonic TC-P42G10 Plasma TV red light blinks 14 times.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Pansonic Plasma s are given in detail. Pull up older posts there.
Posted on Aug 22, 2012
gopakumarg43
  • 74666 Answers
SOURCE: trouble shoot panasonic plasma shutting off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Feb 04, 2015
Panasonic p65vt60 6 blink code
Power board...I bet you have swollen capacitors...
Sep 24, 2016 | Panasonic TC-P65VT60 65" Plasma TV...
Panasonic Plasma TV TC-P50S2 10 blinks
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 11, 2016 | Panasonic Viera TC-P50S2 50" Plasma TV
How do I fix my Panasonic Plasma TV?
Call in a repair specialist. You have done everything you can do.
Nov 18, 2015 | Panasonic Viera TC-P50S2 50" Plasma TV
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
TC-P42ST30 power light blinks twice,replaced power supply board,no change.What to replace next?
Are you SURE you get 2 blinks? I show NO 2 blink code in the 011 model Pana plasma sets. Anyway...if you replaced the PS board and still get a code, unload the VS supply from the SC board and re-check--see if the VS supply comes up--even for a couple of seconds...about 205 volts or so. If it does--re-connect and see if it then does not come up. If not--then the SC board is likely bad (THE most common failure on ANY plasma set is the Scan board ).
Nov 24, 2014 | Panasonic VIERA TC-P42ST30 42-Inch 1080p...
Power lamp flash 6 times
6 times flahes denotes main power regulator board fault. Check for it. To get some information, http://electronicshelponline.blogspot.com/Pull up older posts. Blinking code details to Panasonic Plasma TVs are given.
Dec 02, 2013 | Panasonic TC-32LX60 32 in. LCD Television
TC-P50S30 Plasma HDTV won't come on blinks 7 times
That is a error code and depending (Panasonic?) on model means either power board or another issue---the error codes can sometimes be misleading or too vague to pinpoint to one board.
Note: these (all brands) sets only sell boards, no individual parts.
Not knowing your skill level you may be able to tell me that, the first thing would be to examine the power board for damage or puffed up filter caps---let me know if questions here etc.
Dec 11, 2012 | Panasonic Test Tool Part Tzsc09187
Jul 19, 2012 | Panasonic 65 TCP65ST30 3D Plasma TV
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
Jun 01, 2012 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Panasonic Viera Tc-p65st30 65" Full 3d 1080p Hd Plasma Internet Tv Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
