Question about LG Washing Machines
I apologize - am texting friend also at same time for help - just realized I didn't say it was an LG front load washer
  • kakima Dec 20, 2016
    Hi Anita Korn, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    This appears to be your only post on FixYa.
    What model washer? What's the problem?
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
rickzilla
  • 706 Answers
SOURCE: Getting error code on lg front loader washer
Hello aj546,
Kinda figured there was a miscue there with your error code however... the error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)... If you still get the FE test..call for service.. That's the best I can offer via this chanel... BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open... Hope that helped you..'
Regards,
Rick
Posted on Nov 29, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
maintenacemi
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
I switch on the machince, but on wash mode, machine drains the water? I didn't find solution for the same. Pls help
Make sure the drain hose from the back of the machine goes up to the drain line. The end of the drainshould go up the height of the washer to keep the water from siphoning out.
Hope this helps.
Nov 02, 2011 | LG WM-2277HW Front Load Washer
I have had this phone since October 2009. Yesterday evening it was working fine but last night at 7:30ish it stopped recieving text messages. I didn't realize it until today though I just thought my texts...
Such problems occur when your message center number has been tampered with. Call your service provider to get the message center number go to message settings and check the message center in use input the correct center number and your problem is solved.
Hope this solution has been helpful to you?
Jun 27, 2010 | LG enV3 VX9200 Cell Phone
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
LG washer retaining ring problem
Get a second person to help you. Just slowly start at the top. Have your hands go down each side tucking it in and have your friend prevent it from coming out. I know it's a pain but it can be down. That tool is a life saver.
Dec 12, 2009 | LG WM-1832C Front Load Washer
LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Nov 17, 2009 | LG Washing Machines
Problem with the electrical plug on LG Washer
some times the cords when produced are defective from start, replace it or cut it back to where wire is good, and put a new end on it, then have the running current checked on the unit when in full operation and make sure units not overdrawing and ruining the cord
Oct 26, 2009 | LG WM2277H Front Load Washer
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
