Question about Bosch Dishwashers
Sms6012/sms4472 my bosch smv5503 dishwasher strikeplate is broken cant find replacement, do I need a new dishwasher.
2 Suggested Answers
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
My seven year old Bosch dishwasher has broken down. Should I have it repaired or is it too old and buy a new one.
7 years is close to its lifespan more to the point bosch parts are very expensive in general it all really depends on whats wrong with it?
Oct 08, 2014 | Bosch SPV68L00GB Slimline 450 mm Silver...
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at-
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch Dishwasher model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Jun 06, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
How do i download a manual for a bosch exxcell dishwasher
bosch web site has almost all domestic white good mauals for download in pdf format, type bosch quickfinder into your browser and enter enr or model number into it.,
May 27, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My Bosch dishwasher sounds like it is running but does not clean the dishes.
check bottom of dishwasher screens for any blockages or obstruction preventing water from getting into pump. may need a wet vac to **** water out of pump and use a small mirror to inspect pump openings. if no obstruction, the pump impellor maybe broken. replacing the impellor is fairly difficult. the dishwasher has to be pulled from under the counter. repost if you further questions.
Jan 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
New Bosch dishwasher will not start. Just beeps when you try to start it? Installer is lost as well.
Check the following specifications if your dishwasher is not starting
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Sep 10, 2009 | Bosch Dishwashers
Bosch 3000 dishwasher
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Dishwasher classixx blows fuse when turned on
No don't hose it out. That will only make things worse. There are a good number of reasons why it may be blowing the breaker. You will need to meter out the different parts to check for a short. My guess from you description is that the softner unit has broken / leaked and gone into the main pump. You will need to replace both if thats the case.
Jul 20, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
26 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
