Worked fine day b4 - next day no power /won't come on. Outlet is fine - checked cord on another - still nothing
  • Washing Mach... Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help http://www.partselect.com/Repair/Washer/Will-Not-Start
Posted on Jan 15, 2017
3 Suggested Answers
djz83
  • 88 Answers
SOURCE: atlantis washer suddenly stopped working at all
I would check your lid swtich first.
Posted on Jan 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool duet washer. It worked fine
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Posted on Sep 30, 2010
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
We came home from a weekend vacation and the TV won't turn on at all. there are no lights, no response from the remote, nothing. It worked fine on Friday and now Sunday, it is shot. I thought possibly...
Hi, Check that the plug has power. Use a light to do this. Also check the TV cord maybe bad.
Check breaker pannel. Make absolute sure that you have power getting to the TV. If all is good you need a repairman. Good luck
Jun 20, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Two months old dead no power
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Oct 08, 2009 | ASUS Computers & Internet
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Won't power on
Yep, Stop buying this printer. I doesn't work. You think it might have anything to do with the outlet you are using. I'm thinking some type of power surge or short hit all three printers with the same outlet. Did you plug all three in the same outlet "first thing" when you got the printers home? Are you using a power strip? I find that kind of strange for all three having the same problem. How long did the last printer you bought work? You said it worked great with the old power cord. Plug something else in the outlet like a lamp and see if the cord gets hot. I know that doesn't sound much like a solution but you gotta try something. Printers are getting expensive. Let me know what you did. I'd like to get to the core of this problem.
Jun 29, 2007 | Cannon i70 Printer
Washing Machines Logo
Top Washing Machines Experts
