Question about Canon Office Equipment & Supplies
Canon irc3080i colours out of alignment - Canon Office Equipment & Supplies
Canon irc3080i shows error E000020-0103 at times and cant copy anythinh papers only come out blank what could be the problem?
There is a problem in developing assembly.
Check the toner leakage from the toner buffer block within the developing assembly. Replacing the patch image reading sensor should do the trick.
Dec 20, 2016 | Canon Office Equipment & Supplies
The color red, yellow and blue on my canon ir c5185i are not togeather. How do you adjust them to be one color?
Follow the instructions to align the colours try automatic align first, if no improvement select manual alignment.
Dec 05, 2013 | Canon Office Equipment & Supplies
Canon irc3080i
first remove all paper trays and inspect for paper behind the tray area and inside the machine
second verify if the paper trays are set to the correct paper sizes this is easy just look at the screen under paper trays and all trays should tell you what they are set to
Oct 29, 2013 | Canon Office Equipment & Supplies
Irc3080i e000025 0000
check that the toner bottle is properly insall. see install procedure on the front cover of the copier. jaime
Jul 13, 2010 | Canon imageRUNNER C3200 Copier
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
How to set up a canon irc3080i to enable incoming faxes to be directed to the bypass drawer
If you are referring to the stack bypass and pulling paper for faxes from that tray... you can't do that.
Nov 18, 2009 | Canon Office Equipment & Supplies
old marine
old marine
