Question about Blodgett DFG-100 Gas Single Oven
Electrolux/Frigidaire stove top decals worn off
Need replacements decals - will look better when I put it on the market for sale.
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
Glass top broken,can it be fixed
The glass top can be fixed. You will need to call a parts dealer to order. They usually run a couple hundred dollars. If you are going to replace yourself than you will need to pull the stove out and disconnect power. Than remove the side panels and it allows access to the screws holding the glass top in place. Be extremely careful when replacing these. They can break easily. Make sure you place burners and everything on the new one exactly how they are on the old one. Easy way of doing this is have a couple big towels and set next to each other and switch parts there. Remember that when you put it back together to clean it with glasstop cleaner before you use the stove.
Jun 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Number and temperature decals washed off my stove. I can't even remember right now if its a hotpoint or a frigidaire~ that washed away too!
you can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
Nov 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
MY STOVE
hi thanks for the question .F3 on a Frigidaire stove means that the oven sensor is open that's the part in the oven to the left and top it looks like a pencil replace part from the back of the stove but with 1 screw holding the sensor replace BUT power off please thanks the appliance doc
Sep 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Replacing the ceramic top
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
Jun 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Blodgett DFG-100 Gas Single Oven Logo
696 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
joneable
Level 1 Expert
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
