Question about Garden
Plow lights on low blink. Work on high. Now only truck lights are working. Plows lights don't work at all.2008 western plow
autotherapis
  • 501 Answers
SOURCE: hi, I have a 2000 dodge ram and when i plug my
There is a ground that is deteriorated in the harness. trace the ground lead back from the connection to your truck. Once you find the break, that should take care of your problem.
It is also possible to be a power lead, so check them also, but more often than not it is a ground.l
Hope this helps.
Posted on Dec 14, 2009
  • 31 Answers
SOURCE: my 2008 f-250 looses the
test to see if the lows share the same circuit. it is also possible the bulbs are bad, or an error in the wiring.
Posted on Feb 01, 2011
SOURCE: Lights on a fisher xtreme plow wont work
Check your harness plug ends for broken pins. Also the isolation module could be defective
Posted on Feb 07, 2012
  • 272 Answers
SOURCE: I am installing a western pro snow plow on a 2013
Plz check and follow the wiring to low beam to ensure they are making a good connection. Also, you may want to pull other low beam bulb and put in place of this one to ensure that it is not the bulb. Hope this helps.
Posted on Nov 14, 2013
  • 36580 Answers
SOURCE: I have a hydraulic Western Plow. I just purchased it from a guy that sells used plows for Western plow, and hooked it up. It will lift, lower and turn right. When it turn right, it goes up.
Take this issue up with the "guy (who) sells used plows for Western".
Posted on Dec 10, 2016
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
Beast way to wire up plow lights on a 2008 dodge Dakota sxt 3.7 v6 4x4
Trying To Wire Plow Lights Without A Harness - Snow Plow Forum ...
www.snowplowforums.com/...lighting-wiring/13714-trying-wire-plow-li...
Oct 11, 2006 - 25 posts - ‎8 authors
They both work when I hook up the battery charger to them. ... This way,the plow lights only come on when the plow is plugged in,and ... A relay equivalent to Napa part #AR272 is good, if you give the number at Advance or Autozone they can cross reference it. 92 Dodge Dakota - 7'6" Snoway MT with DP ...Missing: 2008
Meyer Snowplow Install - Part 2 (Electrical) - YouTube
? 10:01
https://www.youtube.com/watch?v=5RSFqO80cLM
May 20, 2009 - Uploaded by CentralPartsWarehse
A real plow install taking place in our on-site, full service shop. In this video we'll show a complete snowplow install taking place on a 2009 ... How much does a complete set up like this cost? ...BEST SNOW PLOWING VIDEO!
Light Wiring for Meyer Plow - DODGE RAM FORUM - Ram Forum
Dec 13, 2015 | Dodge Cars & Trucks
While driving down road my western snow plow is rocking all over.
not good or safe! check all mounting pins and frame mounts. A lot of force is on snow plows and the frame mounts often need to be welded up. I imagine it is the whole unit and not just the plow.
Mar 12, 2015 | Cars & Trucks
Why will my plow not go left
This is a very common problem and is easily repaired - but there are different procedures - depending on the blade Check the link below for a list of plows.
plow blade left and right angle troubleshooting Google Search
Feb 27, 2015 | Cars & Trucks
Western plows
Needs bleeding,got air in the line.
Dec 09, 2013 | Cars & Trucks
I am installing a western pro snow plow on a 2013 Chevy 2500 hd and can not get the left low beam to work all high beams work everything but the left low beam
Nov 14, 2013 | Cars & Trucks
Stalling when going from R to D while plowing snow
It sounds like your draining your battery with all the accessories. It could be a loose alternator belt or that the belt is just getting wet and slipping or your alternator is not up to the job!
Try going to a good auto parts store like Advanced Auto and ask them if this could be the problem. They may be able to swap up your alternator to one that can handle the load!
Good Luck!
Jan 19, 2009 | 2008 GMC Sierra 2500HD 2WD
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
