Question about Pioneer Audio Players & Recorders
Pioneer ct-wm60r reads err, has new belts,
Six tape changer, loads even with out a tape. Trys to rewind, is jammed.? Nothing works.
  • Pioneer Master
  • 1,267 Answers
There are sensors in the unit that are false triggering and some mechanical parts that require alignment. It can take two or three hours to put it back right if you are not familiar with that transport.
This is why I tell people to stay away from changers and auto reverse units as sooner or later they will be a real problem for someone to fix.
  • 104 Answers
SOURCE: Pioneer CT-w602r
once you see the mechanism the flywheel is the largest 'dull' silver colered disc you can see. somtimes a cassette mechanism can be helped along by moving this disc with your index finger.
if it recovers, you have bought a little time but the belts must be replaced. You will need a pro to replace the belts or a really mechanically inclined has over 450 belt sizes but they show no listing for your model as of yet. so you would have to provide belt length info to get the right belt sizes.
Posted on Feb 11, 2009
  • 2992 Answers
SOURCE: I have a Pioneer CT-F700 cassette. This unit is
I don't remember ever working on this model, but it's probably like most others and has rubber belts to drive the supply and take-up spindles. There's also a rubber pinch roller that presses the tape against the capstan shaft, which moves the tape. Those rubber parts by now are long due for replacement. Since the tape isn't moving properly, the auto-stop function is kicking in.
Replacement parts are available, but in many machines it's hard to replace them. Some require extensive disassembly to get at the pulleys. So it's essentially a minor repair, but may be major labor. My only suggestion is that if you want to keep this deck, look for a service shop that works on this kind of equipment and see if they can give you an estimate. You might also search the Internet for a service manual, which would show belt routing and assembly details. Many manuals are available free at low cost from several sites. If you're mechanically inclined, with the proper information you could probably replace the parts yourself.
Good luck and thanks for using Fixya!
Posted on Dec 03, 2010
SOURCE: Sony TC 330 reel to
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Posted on Apr 17, 2011
  • 8546 Answers
SOURCE: I need a diagram that
A simple search engine found the procedure...
Posted on Jun 29, 2011
  • 1267 Answers
SOURCE: The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
Posted on Jul 29, 2012
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
Feb 05, 2012 | Pioneer Audio Players & Recorders
Trying to locate a pioneer cassette player, tape drive belt, for CT 506 model.
I'm not sure what country you're in but below is a link for a complete set of 5 replacement drive belts for your CT-506.
If you need any further assistance then just ask.
Please leave feedback.
May 09, 2011 | Pioneer Audio Players & Recorders
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Pioneer multi cassette changer CT M6R
I have had this same problem too. I fixed it by taking the tape transport out of it and removing both capstans with their flywheels and oiling the capstans. However this only fixed the problem for a few months. Maybe you need to more a most soild oil since i used just regular motor oil.
Oct 17, 2008 | Pioneer DEH-1600 CD Player
Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Mar 16, 2008 | Audio Players & Recorders
142 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
