Question about Water Heaters
My heater lights but center plack blows out and relights
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
2her is pilot light on remeha avantaplus boiler
? 7:54
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
When the wind blows the pilot light out, I have great difficulty in pressing the buttons in to relight it.
You are getting negative pressure in the burner ... this can be caused by the access panel not being reinstalled properly after you relight the pilot. Vents can cause a "venturi effect" and if the access door is not on tight it will indeed become a real pain
Feb 18, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Rheem direct vent gas water heater. When
If you are not seeing a spark at the pilot assembly where the pilot flame lights, then it is probably not sparking in the right place. You may have a short in the wire or a cracked porcelain ignitor, causing it to spark elsewhere. If you can remove the access panel, you may have to relight the pilot manually with a butane lighter. To resolve the issue of the flame blowing out, make sure your vent outside has a cap on it and that the vent is not partially blocked with a bird nests, etc. Hope this helps. Douglas
Jun 27, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have atwood pilot relight model gc6aa-8 pilot will light but after tank heats up & there is no call for hot water,pilot is out and very hard sometimes impossible to relight.
So are you saying that the first initial lighting of the pilot, without turning to on, works o.k., good flame etc, ? If not sure, try lighting pilot only, and leave setting at pilot only, and see if it's a good flame, and get back to me.
May 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
Gas tankless water heater turns off during shower
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Feb 23, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
