My heater lights but center plack blows out - Heating & Cooling
    Habit-Forming:
  • 98 Answers
This is a gas heater? What do you mean by center plack?
Posted on Dec 20, 2016
Testimonial: "radiant behind pilot light"
No heater controls no blower or ac fuses good 89 jaguar xj6
My 93 xj6 doesn't blow or anything but I found that if I kick the blower under the string wheel. It comes on. Then it's blowing cold on the dash and hot out the center counsel. Where do I kick to fix that? There are buttons that light up by the steering wheel. That look like the seat heater button. Is there a way to choose to make the thing blow cold in front and hot in back? 989-657-2563
Jun 27, 2012 | 2001 Jaguar S-Type
Heater shuts off after a minute or two - fan keeps blowing
make sure to unplug the stove take the two rear feet off, remove screws from back you have to bow the back in the center until you can remove it gently lay stove on its front being careful to not damage the door handle.
remove the heater unit from the bottom of stove,there are three screws on each side remove the corner screws leave the 2 center screws until last take a shop vac , clean blower wheel and carefully blow all the dust threw the heating assembly so the air flow isn't restricted. This fixed mine and it works perfectly. the airflow being restricted causes the unit to overheat and shuts off the safety switch.
Dec 23, 2010 | Dimplex DS5598 Mid-Size Heater
I have a glo warm gwrn30a a flame shoots over the top of the center plaque about a inch or sol
Check to see that the center (plaque) is seated in its holder securely. Also make sure these (plaques) are clean and there are no obstructions so gas can flow freely thru them. Easy hint for cleaning them is a compressor and blow gun, using pressurized air and blowing them out clean. Try this and it just could solve your problem.
Dec 22, 2010 | Desa International Blower Glow Warm Wall...
Have an Atwood LP water heater. When I light the pilot light and hold it for 30 seconds or more it stays lit but the burner tube will not light except for at the air/fuel mixture slits at the thermostat...
Yes, a good place to start would be to run a burner brush through entire tube to make sure all spider webs are out, then blow through again. If that doesn't cure it, double check your position of burner tube in chamber. Sometimes if it's moved into chamber too far, it will tend to back-up flame in to tube. I've had some that I re-installed and was sure I put it back exactly where it was before, but had to pull burner tube back approx 1/8"-3/16" to get a proper flame. Make sure it's centered in chamber as well.
Dec 06, 2010 | RTO Atwood Water Heater - 6 Gal LP
Fan blows, but heater display doesn't light up. blows out cold air only. no heat
Check fuses to the A/C or Heater Control Unit in the fuse box(es). IF none are blown, then may have to replace A/C-Heater Control Unit:
A/C-Heater Control Unit Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Center bezel from the instrument panel A/C-Heater Control chr_pacif_ac_htr_cntrl.gif
    • Three screws that secure the A/C-heater control to the instrument panel
    • A/C-heater control from the instrument panel
    • Two wire harness connectors from the control
To Install:
  1. Install or connect the following:
    • A/C-heater control to the instrument panel
    • Two wire harness connectors to the back of the A/C-heater control
    • A/C-heater control into the instrument panel
      1. Torque to: 17 inch lbs. (2 Nm)
    • Negative battery cable and calibrate the A/C-heater control
Nov 06, 2010 | 2005 Chrysler Pacifica
Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Jul 13, 2009 | Dishwashers
Merc c class heater problems centre blowing cold and sides hot
Bad vacuum pod, try using a mini vacuum and the on the valve block behind the glove box take suction on each one till you find the bad one.
Jun 10, 2009 | 1996 Mercedes-Benz C-Class
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Infared burners with flame at the tops of them
This may mean that the plaques are cracked, if they are cracked you cannot repair them, you would just have to replace them. You can contact Master Parts they may be able to help you. You can contact them toll free at 800-446-1446. Thank you
Nov 10, 2008 | Procom ML300HGA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
