Question about Refrigerators
My Kenmore refrigurator compressor shakes and makes a loud noise in the compressor when the compressor shuts off. It sounds like something is moving around inside it. It seems to be keeping the refrigurator and freezer cold. Is my compressor failing or what may be the problem?
  • 65 Answers
Is your frig is on perfect level?
yes it could be a sing of a soon breaking compressor
Posted on Jul 21, 2009
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Compressor makes brief but loud rattling noise when it shuts off. Other than that the refrigerator is operating properly.
There are rubber shock mounts between the bottom of the compressor and the fridge frame, if any of these are worn it can cause that sound. Sometimes the condensate tray is what is actually making the noise; when the compressor powers down it vibrates and causes the metal tray to shake, maybe bumping the side and creating the noice. Pull the fridge off the wall and take the cover off the back of the fridge. Be careful, there's some voltage going through there. Locate the condenstae tray, shake it gently and see if it's loose. Give the compressor a gentle push and see if that makes the sound. Usually it's one of those two things and not an actual problem with the unit. When you touch the compressor, be careful, they can get pretty hot.
Jan 03, 2011 | Kenmore Refrigerators
My old side by side Kenmore with Icemaker makes a loud rattling sound when it stops running. It is the existing refridgerator from when we bought our house so I don't have any warranty info on it. Any...
If the noise is loud enough that it sounds like somone knocking at your door then it is probably going to be the compressor. There are internal springs and is possible one broke. The only solution is to replace the compressor. It is also possible that the condencer fan motor is hitting something as well when it shuts off. You would have to look at it from the back as it shuts off after running.
Nov 02, 2010 | Kenmore 53642 / 53644 Side by Side...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Loud noise when stops ''running''.
the noise your hearing  is a weak spring in the compressor. what happens is the compressor is a motor inside of a steel shell that spins at high rpm's when the unit shuts down and as the compressor starts to stop the weak spring is allowing the compressor motor to bang against the steel shell. around here we actually call these "Bangers". anyway the fix is obviously to replace the compressor. but considering the age of the unit you may want to move it to the garage and buy a new one for the kitchen.
Btw in my experience this does not interfere with normal operation of the unit it is just annoying. If I can be of further assistance please ask thanks Peyton
Mar 06, 2009 | Refrigerators
Kenmore Frig Noise
TD, sounds like your valve springs in the compressor let loose and it's banging on the side when shutting down and equalizing. The compressor has a 5 year warranty. This is more annoying than anything. If it's under warranty, have them replace it. If not, it's up to you whether you want to live with it. Catriver.
Dec 16, 2007 | Refrigerators
Loud banging noise
some popping noise is normal but if it is banging when it stops it needs a new compressor.what has happened is one or more motor mount is broken or weak it could run like this for months or years but it is annoying! if its warranty they have to replace it.
Dec 11, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
239 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
