Question about Procom Heating & Cooling
Procom pcsd25 will not let gas thru gas valve.good gas pressure, 60% tank, orifice clean,solenoid has magnetism,pilot stays lit.Any ideas?Been on hold at procom service for 45minutes.
    Problem Solver:
  • 10 Answers
Bad valve. Replace.
Posted on Dec 24, 2016
Pilot flame noisy and lifting on procom ml150tpa heater; how to adjust the flame
Take the valve apart and make sure the seal on coil is not damaged have also seen the snap ring come off
Mar 04, 2014 | Procom Heating & Cooling
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
I cannot get the pilot light to stay lit. I disconnected the burner orifice and to see if the gas was getting through as it seems as if it is.
Several things can cause the problem you're having.
1. Low gas pressure due to a near empty tank or the heaters regulator is locked up and only
allows a small amount of gas to get the pilot. To solve this, turn the gas tank valve OFF & dis-
connect the hose from the tank. Wait 5 minutes & reconnect the hose to the tank. Open the gas
valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the pilot
and hold the gas control valve in for 30 seconds to 60 seconds. After that time, release the control
valve knob. Did the pilot stay lit? If so, problem solved. If it didn't you will need to replace the
heater's Hose/Regulator Assembly. You can use the same one that's for a gas grill. And find it at
any hardware store or home center that sells grills and accessories for about $30.00.
2. The pilot is dirty and needs to be cleaned. Use a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the pilot tip.
3. The thermocouple has failed and needs to be replaced. If this is the case, you can order a new thermocouple for Blue Rhino (1.800.762.1142) , the manufacturer of your Patio Heater.
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Endless Summer 153100 Open Flame Patio...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
Sep 21, 2011 | Water Heaters
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Pilot light not staying lit, changed thermocouple, start up proceedure normal until the pilot button released.
Some things to check:
Make sure the thermocouple is squarely in the pilot flame and that the pilot flame is large enough to envelop the thermocouple. A weak pilot can be caused by gas pressure or a carboned-up pilot orifice (where the gas comes out). The orifice may need to be cleaned. Ordinary automotive carburetor cleaner will work. Don't try to stick objects into the orifice - damage may result. If you need to perform this step, make sure the gas is turned off to the heater first.
Make sure the other end of the thermocouple is clean and tight in the gas valve.
Hold the pilot plunger down for at least a minute to be sure to give the thermocouple enough time to heat up.
Mar 15, 2010 | Water Heaters
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Pilot wont stay lit installed new gas valve and new thermocouple
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Jan 28, 2009 | Dayton Gas Furnace Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jan 07, 2009 | Procom (177653) Utility Heater
Heating & Cooling Logo
52 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
