Question about Pride Health & Beauty
I have a motor/brake code showing n a pride mobility j6 power chair showing up on the controller? The power recline and leg rest still work? Any ideas
  • 175 Answers
SOURCE: How do I remove the chair from my Pride Mobility
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Posted on Jul 11, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced.
Posted on Sep 07, 2009
  • 280 Answers
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Posted on Nov 25, 2010
  • 1998 Answers
SOURCE: my pride go chair controller
How many yellow are flashing constantly? take a look at this link as well is this the type of controller you have and the type of display for the bars
if you have any further questions message me back and please remember when this chat is concluded to rank how this opinion has helped in your situation Thanks again
Posted on Dec 25, 2010
  • 692 Answers
SOURCE: When I turn on controller
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Posted on Apr 28, 2011
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ... > Resource Center
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Dec 03, 2015 | Pride Mobility Pride TSS300 Power Chair -...
Lights show code 8, controller issue, how do I fix
hi yes code 8 is a controller error try ringing a pride spare parts to c if they have reco ones .....very expensive new ones try monster scooter parts ...good luck
Aug 30, 2015 | Pride Mobility Jet 3 Ultra Power Chair -...
COPY: "Add more details"? Certainly will add a detail I feel is very important. This power chairs' undercarriage lowest height-above-ground is ONE HALF AN INCH. I have mistakenly driven over a large "
It could be a brake trip/free wheel
it could be a communication fault. This is usually an intermittent connection in the circuit. I would make sure all connectors are secure. The best way to do this is to disconnect and reconnect. Even do the ones going into the controller also.
if these do not help, you may need a tech to check it out. They will go thru the same process. The only additional thing they can do is get online with the controller with a programmer that will give them additional fault codes that sometimes can be more specific as to what the problem is.
I think it's most likely a brake fault. Make sure the freewheel on both motors are in the engaged/locked position.
Worst case, your controller may be bad.
Apr 10, 2014 | Pride Jazzy Select 6 Indoor Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Pride JET 3 Ultra power wheelchair. Problem: Batteries drain very fast after recommended charge. Things I have done: Replaced both batteries- twice; Replace On-board charger. Both items brand new. ...
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jun 10, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Hi, I have a jet 3 ultra chair . I have just put new batteries on and can still only do about 4 miles from a full charge, any ideas, Many thanks Rolfe
Rolfe could be a couple of things check the brushes in each motor for excess wear and check to see if the motors are getting overly warm after driving for awhile if they are then you could have a brake problem on one or both of the motors. If your brushes are less than 1/8" long then they need replacing and you can have a provider order some from Pride for you or have them service the motors for you. If it is the brake then it will have to be replaced by a tech who knows what to do if you can get the brake from Pride. Now I'm not suggesting this or recommending this because of safety and liability issues but you could remove the brake from the rear of the motor that is getting hot (if it is) leaving the wiring connected and hang the brake in the rear of the chair so it won't break the wiring and drive the chair to see if that makes a difference. If you remove the brake and wiring then the chair won't move at all because the controller is looking for the brake when you turn on your chair if the wiring is disconnected you will get a fault error and the chair won't move. Also have someone load test your new batteries just because"new" doesn't mean good and a weak battery will reduce distance driven. Hope this helps
Mar 18, 2011 | Pride Mobility Products New Pride Mobility...
I have a quantum 6000 chair and whenever I need to raise my chair for a period of time, my legs just dangle and begin hurting. Any suggestions or solutions for a temporary foot rest while my chair is...
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
Nov 12, 2010 | Pride Mobility Products Quantum Jazzy 500...
Health & Beauty Logo
128 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
