Question about Boating
Why does my 8 hp honda outboard decide to go to full throttle
This engine runs flawlessly but sometimes, on three know occasions, it races to full throttle, independent of throttle linkage. The only cure was to turn off the key. It happens in gear.
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 508 Answers
SOURCE: how to remove shift rod linkage to pull lower unit
goto local library get book on unit!!! :)
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
  • 53 Answers
SOURCE: Honda outboard engine 50hp nrepair manual
Here is a link to clymer manual. honda won't allow free manuals posted online. you will need to purchase. click here
Posted on Nov 05, 2009
wireguy212
  • 1627 Answers
SOURCE: John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Posted on Jan 19, 2010
How do l fix an outboard motor that runs fine for about 5 minutes at full throttle and then abruptly stops and will not start until it sits for awhile?
Check that the priming bulb is fitted with the arrow pointing in the directions of flow to the engine. Make sure the vent is open on the fuel tank. Check all fuel lines for kinks or blockage. If none of that fixes it, you need a marine engineer to check the fuel pump and carbs.
May 13, 2016 | Boating
1993 Johnson outboard while running good will go from full throttle to barely running sometimes 5500 to 2500rpm. Carburetors rebuild gas lines good and good spark.
If your boat has a inboard tank check the Anti Siphon valve. Try to run the outboard on a separate fuel tank to isolate the fuel source to see if it is the boat or the engine. A clogged vent line will also do that.
Mar 30, 2016 | Boating
Starts up, then why does it cut out when going to full throttle?
possibly overheating try running slower which creates less heat
Oct 25, 2015 | Yamaha Tilt Trim Motor, 115-225 HP...
Please only marine mechanics reply I have posted a question about my 90 hp force outboard the warning sound starts sounding while running full throttle after about 15 minutes of running full throttle I can...
Is this motor used in salt water?
That warning buzzer on your motor is really only tied to the temperature. In order to triage sensor or overheat condition, I'd recommend an infrared thermometer to get a reading on the engine as the buzzer is sounding. There is a product that is like a glue stick which can be pressed against the engine which melts at a very specific temperature... not sure if it's around anymore as the remote thermometers are pretty inexpensive now. Is there good water flow out of the ports below the cowling on the back?
May 01, 2017 | Mercury Force Starter, , Sport Jet,...
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Honda 125 nsr 1990 wont idle and engine races
sounds like your throttle cable might be frayed or broken, when you pull the throttle and let go does it go back on its own? and can you here a clicking sound when you close the throttle? If you could send me pictures of the carb how every thing goes in and take it apart and take pictures, that would be helpful.
Jun 12, 2010 | 2001 Honda NSR 125 R
What is the rpm of a honda 8 hp engine
full throttle it is 4500-5500 RPM
May 19, 2009 | Honda 8 HP Engine
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Boating Logo
87 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
