Question about Boating
Honda 8 hp outboard accelerates to full throttle on its own. Has happened three times; otherwise runs great. Why?
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 14 Answers
SOURCE: does my 2000 honda 4 stroke 8 hp outboard have a fuel filter?
Your tech may have missed one or two parts of the idle circuit. There is an idle mixture screw hidden under a brass plug (to prevent tampering on the top of the carburator. This passage needs to be cleaned and idle air mixture screw adjusted properly.
There is also an idle air jet located close to the idle mixture screw. The jet should be removed and cleaned as well as the passage that it came out of. The jet is a small brass piece with a small hole and a standard screwdriver slot. Unscrew this, spray brake cleaner through the little holes and spray brake cleaner (using the little straw that comes with the brake clean) into the hole in the carburator. Take some compressed air ( from a small can of compressed air that you use to clean your computer) and spray into the hole. Reinstall the jet and see what happens. If this does not fully fix it, I would return it to whomever originally cleaned it. If the dealer is worth their salt, they will fix it (if they did not clean in the first place) Everybody makes mistakes.
Also, be sure that your oil level is not too high. It is better to be a little low than too high.
Be sure to be using NKG spark plugs DR5HS I assume that both spark plugs look ok.
The other item that affects this motors idle is the thermostat. Feel the top head of the motor. It should be about 130 degrees. Not hot enough to only just touch, but not cool enough to be able to keep you hand on for 10 seconds or more. A temperature gun would tell you for sure, but most people do not have those is their back pocket.
Timing could be an issue, but normally, it would affect all speeds of operation.
A lot of things for such a little motor.
Posted on Aug 10, 2009
  • 770 Answers
SOURCE: 1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Posted on Sep 20, 2009
  • 53 Answers
SOURCE: Honda outboard engine 50hp nrepair manual
Here is a link to clymer manual. honda won't allow free manuals posted online. you will need to purchase. click here
Posted on Nov 05, 2009
1973 Johnson 65 hp outboard. It runs smooth, but won't accelerate at full throttle.
have the carby professionally overhauled
replace all rubber hoses from the tank , including having the fuel pump overhauled
the rubber parts break down and deposit small bits rubber in all of the jets in the carby
Jul 20, 2017 | Johnson Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Engine runs idles great slow speed until throttle up then shuts down
Depending on where you are, you could be getting carbeurettor ice. It's rare, but has happened to me with a 35hp outboard in early morning when temp was just above freezing but humidity was high.
May 20, 2015 | Boating
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Jan 27, 2014 | Clymer Marine Maintenance and Repair...
30 hp 4 stroke carburator problem
Check your "sync n link" of the throttle pick up and the ignition timing.
Aug 05, 2012 | Seloc Mercury Outboard Engine Repair...
I have a Suzuki 4 stroke 40 HP outboard motor that sputters while in full throttle. How can I fix this?
this sounds like the high idle circuit of carberetor has debri in the needle. I would consider cleaning carb and try again. If still continues then this would make me look at fuel pump. These 2 things are where you need to start.
Mar 22, 2012 | Boating
30HP JOHNSON OUTBOARD RUNS FAST ONLY WHEN IT WANTS TO!
is it one coil for each cyl or a double ht ? if single coils swop over and see if problem moves ! if double ht then swop leads over if you unbolt the coil and fit an earth wire to the coil body and try in a dustbin of water ! sometimes the ht are too short to swop ! check connections and earths !
Jun 11, 2010 | Light Outboard Motor Boat Bass Fishing...
My honda activa doesnt have pick up. when i keep in choke it runs properly otherwise. i had given it for servicing they replaced airfilter but still it is not working properly
What your doing with that sissy queen bike, get a rat rod bobber or a 5150 hard knock
does your scooter makes a loud noise, then stalls when I'm riding it. What's happening?
You're flooding the engine out. Read the manual and break it in before doing full throttle runs. After the scooter has been properly broken in, you can accelerate to the speed you wish to ride, then back off of the throttle to maintain the speed. If you hold the throttle wide-open, it will flood the engine and stall the scooter which may cause damage.
Dec 13, 2009 | 2005 Honda Activa
Aug 27, 2009 | RTO Oar Sockets
Hesitation on acceleration engine runs fine otherwise
My 99 Audi A4 2.8 Quattro was havinga problem starting at times. It would idle poor upon start and then it would come up in rpm where it should be. I had hesitation from a start and after coasting for more than 5-8 seconds, the car would shake violently upon acceleration at about 1/3 throttle. I cleaned the Mass Air Flow Sensor. This helped but did not solve all my problems. I then replaced the Mass Air Flor Sensor. Little to no change there ($108.00). Lastly, I replaced the spark plugs. I bought Bosch plugs ($4.82 ea.). This got rid of all the symptoms. I had bad lugs and possibily a dirty MAF!
Mar 19, 2009 | 2004 Audi A4
Boating Logo
95 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
