Question about Boating
Honda 8 hp goes to full throttle for no reason- not a linkage problem. Only solution was to turn off ignition key. Otherwise runs perfectly. Has happened 3 times. Is this a computer flaw or what?
  • 103 Answers
SOURCE: 96 Honda Accord ignition Key problem
I might try checking with the dealer for a recall on this one
Posted on Jan 10, 2009
  • 14 Answers
SOURCE: compaq presario desktop computer sr1130nx on/off switch
To trouble shoot this problem,I would open the case and make sure the cable are tight from the power switch to the motherboard, you can do this by sliding off the front of the case.
Once the front case is off you should be able with a pen or pencil push the switch slightly to turn it on. But watch and see is how far down the on/off switch goes in.
Posted on Jan 23, 2009
SOURCE: Car beeps 3 times repeated 8 times when igintion goes to off
3 beeps repeted 8 times for the toyota carme 1992 means that the sun roof is still open.
Posted on Mar 18, 2010
  • 5 Answers
SOURCE: Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Posted on Sep 06, 2010
  • 3740 Answers
SOURCE: engine starts ok. stuck at
Hi and welcome to FixYa I am Kelly,
First off parts source:
Next engine service manual:
Governor and controls is in section 4 page 34 (begin) though page 40 (end)
This should be what you need to correct the problem. Just make sure that one of the pieces of the carb had not fallen off of the throtle control.. (butterfly x 2) They are mounted with screws onto the throttle shaft and if one comes off.... all the adjustments on the governor have to be un-done....
Thanks for choosing FixYa,
Posted on Jul 30, 2011
I have a Honda Elite 1998 CH80. Throttle won't increase when handle is rotated. I replaced jets and checked vac housing, adjusted needle height. Engine turns fine. Runs great at one speed.
With the engine off, Check the linkage cable from the handle to the carb, making sure , at full throttle at the handle the carb is at full throttle.
May 15, 2014 | Kitchen Ranges
Brand new gx390 Black Max generator backfires when shut down. Might this be plug gap problem?
If you can access throttle linkage to the carburetor, slow the engine speed to idle before turning off. As mentioned in the previous answer ... turning off the fuel valve and letting it run dry is good if you are not planning to use it real soon.
Aug 11, 2011 | Honda Electrical Supplies
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
5 hp b&s runs at idle but when advanced to full throttle it stays at idle. Suspect linkage problem . . . Any answers?thanks jim from lafayette louisiana
It could be the linkage, but the most likely problem is the throttle has gummed up in the idle position. Put thin oil or spray carburetor cleaner on throttle and move it back and forth to work it loose. I've seen it many times after an engine sits for awhile.
May 21, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Muffler rurns red hot after I rebuilt the carb
try setting air and fuel adjustments at 1 1/2 turns each. should solve the problem.
Jun 05, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
What is the rpm of a honda 8 hp engine
full throttle it is 4500-5500 RPM
May 19, 2009 | Honda 8 HP Engine
Boating Logo
89 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
