Question about Cell Phones
I have problem with touch screen .. the menu option and all the top does not let it see when I give menu appears is hoops
  • kakima Dec 20, 2016
    Hi Dery Niebles, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
3 Suggested Answers
djromann
  • 158 Answers
SOURCE: its not showing the main
OK, you have an chinese copy of N8. Try to put the SIM card in the first slot, then into the second and try to power it on.
Posted on May 31, 2011
  • 142 Answers
SOURCE: We have an LG LCD
first u remove the cells of remote. if the menu appears then we are sure that remote is working properly & fault is in tv. then find the menu button on the front panel. when menu appears operate with panel switches. if menu disappears & come again it means that any of the front panel switches is stuck. u need to replace the front panel switches or if it does not disappers the main board is defective.
Posted on Sep 21, 2011
I want to put my facebook account on my phone menu i have two accounts
If you use the fb app, most touch screen phones allow you to do so by pressing on the Facebook name in the list, holding it down until a drop down menu appears, giving you the option to "pin" it to the home screen. Once you've done this, you can also pin your page itself to the screen by going to your profile and selecting thus option.
Aug 29, 2014 | Computers & Internet
Tip
How to make a high battery percentage iPod Touch 4.0
<p>By default, the iPod Touch gives you the remaining battery life with an animated image of a battery. When looking at the battery icon, you can estimate your rate is available and decide whether to load it. For a more accurate indication of your battery life, you can assess the use of the battery, which tells you the exact percentage of battery life you have available. IPod touch with 4.0 IOS software you can enable this feature in a matter of seconds. <br /> <p><br /> <p>1. Tap the Settings application on your iTouch 4. From the main menu, locate the application on the first page. By default, it appears near the bottom of the screen, indicated by a gray icon. <br /> <p><br /> <p>2. Tap "General". It has a small version of the same gray icon that you have already entered. <br /> <p><br /> <p>3. Tap the "Use" option, you can find near the top of its "General" options screen. You will see a list of relevant information about the battery life, including the extent of use since the last load and the amount of waiting time since your last payment. <br /> <p><br /> <p>4. Touch the cartoon "Battery Percent" switch on top of the screen. Tap the button to toggle between "On" and "Off" options. By switching to "On", the percentage of your battery available in the upper right corner of the screen. Tap again to "Off" position when you want to remove the percent sign, the battery of your screen. <br />
on Aug 05, 2011 | Computers & Internet
How to Delete a Contact on HTC G1
From the Home screen, press the Applications Menu. Search for and tap on PEOPLE. Locate the contact you want to delete and do a 'long press' (Touch it and keep your finger there). A menu will appear giving you the option tio DELETE.
Jul 26, 2011 | Cell Phones
RPE POS, multiple menus, no instructions were found to add menu items to a specific menu.
To select which menu you want to change, go to OPTIONS screen, SETUP, TOUCH SCREEN CONFIGURATION. Click on the top right button, SCHEDULE: DEFAULT. A list of your menus will appear and you can select which one you wish to edit. If only DEFAULT appears, you do not have multiple menus, at least on this station. Each station can be programmed differently. If you need outside hep with your menu, send me an email.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
May 24, 2011 | Pc America Restaurant Pro Express
When i turn my ds on it goes to the action replay before anything pops up it turns white even before datel shows up
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing up on the POWER switch.
    3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
    5. Tap the Options icon.
    6. Tap the Start-up Mode icon.
    7. Tap the top box for "M Manual Mode" and tap the "Confirm" rectangle.
    8. Wait for the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Mar 25, 2011 | Datel Action Replay for Nintendo DS
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
Iphone
When view photos, the related menu and action items are not displayed. When viewing a photo you want to erase, tap the center of the photo will case the menu to be displayed at the bottom of the screen. A trash-can icon appears on the right-hand side of the menu. Touching the trash-can brings up a two-button option -- "Delete Photo" and "Cancel". Touching "Delete Photo" will erase the photo.
Dec 18, 2007 | Apple iPhone Smartphone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
