Question about Pool & Spa
We installed a new heater core. wnen we turned on the spa. it went in econey mode. I tried to get it in standered mode by hitting heat button and light button . I got every mode but standered
    Top Expert:
  • Pool & Spa Master
  • 7,374 Answers
Possible bad display
Posted on Nov 12, 2017
  • 5 Answers
SOURCE: No Heat from Spa
Heater contactors "buzzing": Do you mean normal buzzing or extra loud buzzing? Loud buzzing or chattering can be caused by low voltage to a contactor. If normal sounds, then probably the relays on the contactors is working, but the contacts may be stuck, or burned enough so as not to make contact. First, get a voltmeter and check for 240 volts AC at the heater contactor terminals. If the voltage is low, most likely you need to check the contactors further. Check for dirty contacts, clean if needed. If the contacts are not moving when energized, then you will probably need to replace one or both of the contactors.
Posted on Jan 18, 2009
  • 22 Answers
SOURCE: My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Posted on Feb 21, 2009
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
  • 125 Answers
SOURCE: service light is on say's to reffer to manual
Trouble shooting guide and Owners Manual
Posted on Mar 04, 2009
  • 3433 Answers
SOURCE: Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Posted on Jun 01, 2009
How to turn spa heater with Jandy PDA?
normal running is pool mode turn to spa mode then enable spa heat it should work in not need more info
Sep 22, 2015 | Jandy Pool & Spa
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
How do I turn on the spa on AquaLink rs8
go down on controller to equipment highlight it will give you all your equipment pool mode spa mode then make sure your pool and spa heat is activated if you want it to be heated hit the button once then it goes to a 10 minute safety shutdown before the other mode comes on
Jul 24, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Hi, I have spa form prestige 50 and i cam home from work and it had cut out, I restarted the jacuzzui and it went though the 4 minute prima mode and then cut out again. Please can anyone give me some
it sounds like the heating element is out. Undo the wires going to the heater and then turn the breaker back on. If the heater is bad then it will go through the purge cycle and continue to run but obviously not heat.
If this is the case then you need a new Spa Part heating element.
On the heater tube is the information you will need in order to find a replacement.
US Parts Center
Aug 27, 2012 | Jacuzzi Pool & Spa
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
Heater control wont heat. AC and fan works fine
mechanical or vacuum operated valve that releases hot coolant into the heater core may be stuck closed. or the heater core may be clogged. hope this helps.
Aug 10, 2008 | 1997 Pontiac Bonneville
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
