When clearing the adding machine the the screen shows -0- but the tape shows a 1. Can't figure out how to clear/reset this.
  • kakima Dec 20, 2016
    Hi Jeff Dornburg, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Jeff Dornburg
    Jeff Dornburg Dec 20, 2016
    It is a Canon MP25D adding machine
  • 208 Answers
SOURCE: paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Posted on Dec 07, 2007
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
  • 1891 Answers
SOURCE: The machine seems locked on 1 hr..wont clear or
unplug or turn off power . turn back try to program . if no luck / look for code on digital display . if no code replace the touch panel .. it has a stuck touch pad. ,, mm
Posted on Dec 07, 2009
  • 77947 Answers
SOURCE: My Sharp EL-2630PIII calculator has
turn the machine on its back, there you will find 4 or 5 screws, remove them and separate the cabinet from the chassis bottom, this provides access to remove the paper jam. also below find a link to the user manual on pdf.
Posted on Oct 21, 2010
  • 27 Answers
SOURCE: reset machine
turn off machine by pressing power button hold down temperature button on front panel turn on machine while still holding temp button in quickly release the temp button and press the soil button. release the soil button and you should see a diagnostic mode on the screen there will be several sets of numbers on the screen the first set are number of wash cycles then the most recent three fault codes indicated with f1 f2 etc the last number is the software version in the computer when you can see this on the screen you will be able to reset the machine simply by turning off the power and then on again the fault code should then be gone
Posted on Dec 19, 2010
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
Bizhub 211 reset
1-Turn the machine ON. 2-Press "Utility" button on front panel. 3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1. 4-service mode will appear on LCD screen. 5-Now with the help of arrow keys go to the last option.which is "Clear Data". (6) Now select "Memory Clear", clear the memory by clicking "Yes" or "OK" button. Wait for a while, a new code will appear on screen. Now again go to the service mode and go "ADJUST" option and with the help of arrow key select "Model setting" option and press "OK/YES" button. Now in the model setting menu select "16" which is the copy per minute speed of your photocopier machine. Select this option and press "OK/YES" . Now restart the machine.
Nov 25, 2013 | Dishwashers
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Sep 05, 2011 | Canon SmartBase MP730 All-In-One InkJet...
Error code C2557
Error code c2557 means "ATDC Sensor abnormality".
It appears due to following reasons,
1-Imaging unit (Drum unit) parts life is expired,
2-Developer's life is expired,.
3-Developer tank is hard, gears of the unit are not moving
For best results and smooth functioning of machine, simply call your technical services representative and he will help you in this matter.
if you want to do it yourself, you have to do this.
1-Press "UTILITY/COUNTER' button on the machine's panel.
2-Now press "check details" button. (appeared on the lcd screen)
3-Now press these buttons,
4-now press "Tech representative choice" button on LCD screen.
5-now press "PRINTER" button.
6-press "ATDC GAIN"
7-Now press the "c" button to clear the value, after clearing the value enter new value by using numeric pad.
Enter new value by adding 10 to the previous value. For example if the previous value was 150 you have to enter 160 now or 165.
8-Enter the new value and press the End button on the LCD screen and exit.
9-Now restart the machine..
Nov 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
I have a problem with my ti 83. i am traying to graph a equation and it shows me ERR:INVALID DIM 1:QUIT
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Feb 19, 2010 | Texas Instruments TI-83 Plus Calculator
Affter adding developer to my konica 2223, How do I reset the machine. (to clear ''routine service req'' on the display.
turn the machine off hold down 4 and 7 key turn on enter 9 0 then the date power off then on while holding 47 again and press 5 1 and start if you dont run the 5 1 you will get an error code and not be able to use the machine
Sep 29, 2009 | Konica Minolta Office Equipment & Supplies
My Copier is showing 0-8 problem and is not working how to fix it?
Try reset the error by following this step :
Perform the following procedure to enter the simulation mode.
["#" key] [Interrupt key] [CLEAR key] [Interrupt key] [1] [4]
[START key]
The machine will be reset and hopefully your trouble too.
When the CLEAR ALL key is pressed, the simulation mode is cancelled.
May 26, 2009 | Sharp Office Equipment & Supplies
Ricohh 450. Error code E544 or E-5 comes up. What can I do to fix
This is a fuser error code. Sometimes it is caused by a mis-reading. Use the procedure below to reset this machine.
Press the yellow "clear modes" key then pres 1, 0, 7, then press AND HOLD the red "clear stop" key until the screen changes. After the screen changes, turn the machine off at the red switch on the front of the machine. Turn it back on.
If the code comes back you will have to call a service tech to troubleshoot and replace parts.
Nov 25, 2008 | Ricoh Aficio 450 Copier
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
Cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Sep 14, 2007 | Office Equipment & Supplies
32 people viewed this question
