Question about Saws
Seed and nut grinder sg 10 stuck - Saws
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
How to remove wheel on delta 10' grinder
Unplug it first, if you like your skin.
Use a wrench on the nut, and hang onto the wheel with one bare hand while you turn the nut in the same direction as the wheel normally spins. If you have a lot of difficulty doing that, jam the wheel with a piece of wood.
Feb 01, 2014 | Delta Grinders
Are mortar and pestle better than electric grinders?
It depends on what you need to grind. Some electric coffee grinders are very good for certain seeds for example, while substances like basil come out better tasting and with a nicer color when crushed with a mortar and pastle.
Also, if you need to produce big quantities of ground substances it would probably take you a long time to do it with mortar and pestle, and using an electric grinder would help you speed up the process.
Sep 12, 2013 | Home
What is the difference between nuts and seeds?
The basic difference is that all seeds are surrounded by fruit and all nuts have a hard shell.
Jan 10, 2013 | Cooking
Lock nut on Makita GA4030 is stuck.
Because the locknut on grinders are threaded to be self tightening, they can get lodged on quite tight. If it's stuck that bad, put the body of the grinder snuggly in a vice but don't crack the casing. Make sure the arbor lock is seated well and put all the pressure you can on the locknut wrench you can muster. If it still won't come loose, squirt some liquid wrench on the arbor-locknut gap and let it soak in.
Feb 16, 2012 | Makita Saws
How to make malunggay oil
Hi xhaikamsa..
To extract malunggay oil from the seeds of the malunggay plant you need to have a "seed oil estracter"...like the ones on the websites below.
Please take time to rate me thumbs up
http://www.ebay.ca/itm/Nut-Seed-Oil-Press-Manual-Screw-Biodiesel-Expeller-/160586162723?pt=LH_DefaultDomain_0&hash=item2563ae6223
Sep 12, 2011 | Computers & Internet
I can hear the grinder on nuova simonelli try to gring, but it seems like soemthing is stuck. how can i fix this?
Remove the bean hopper and vac out all beans, then remove black cover, then 3 phillips screws, and top part of burrs should come off. Clean our chamber then reassemble. DO NOT TURN ON. Make sure middle nut in chamber spins freely, use fingers to turn, if not adjust setting to coarser, until it moves freely, then turn on grinder. All you have to do now is set your grind.
Jan 03, 2011 | Nuova Simonelli MDX Electric Grinder
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Lock nut on Makita 9069 is stuck & I can't loosen it. Using the lock nut wrench, but it won't budge. Any suggestions?
Make sure you are turning wrench and nut clockwise to remove nut and counterclock to put back on,you will never get nut off if turning counterclocwise,threads pitch is opposite to screw pitches.
You are tightening and did not know it maybe???
Other option:
Need to put lock nut wrench in a vise jaw and clamp, then place tool on wrench and press down and turn. This should give you added leverage to break loose nut,and btw make sure to turn clockwise to unscrew and clockwise to tighten,this is opposite of what you might do to tighten or untighten
Apr 09, 2009 | Makita 9069 9" Angle Grinder
Saws Logo
70 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
