Question about Kroy Office Equipment & Supplies
A manual for the Kroy DuraType 210
Looking for a manual for the Kroy 210 labeling system?
The unit does not get power were do I start to trouble shoot
You checked the electrical outlet with a lamp? OK? check the electrical cord snug plugged in? both printer and wall. Third pull out label roll power on any indicators come on? clear all print jobs to the printer. check the web site of the printer for any update problems.
Nov 17, 2015 | Kroy K4100 Thermal Label Printer
MIS ALIGNMENT OF LABELS
Not enough information provided to allow us to diagnose this problem. You might want to give us a call at (757) 357-2677. We're Hanover Technical Sales, Inc., Kroy's premier sales and support dealer. Ask for Don and inform him that you got his name and number from FixYa.
Apr 07, 2014 | Kroy K4100 Thermal Label Printer
K4350 300dpi, Windows 7, Bartender 8.01 build 2160, USB to Serial Converter, COM3 9600,8,n,1, Flow Control - any setting. 7/16" flat (1/4"dia.) Heat Shrink. After I print a label, the printer beeps an
Your Bartender software is probably set to print individual labels with a gap between them. Reset the software (document properties button) to Continuous label supply, and it should work. Still having problems? We're Hanover Technical Sales, a Kroy Support Site and Distributor. Give us a call at 757-357-2677 and we'll help you get to the bottom of it.
Jan 12, 2013 | Kroy K 4350 Printer
I need driver for windows 7
google with" k4100 thermal printer driver for windows 7 os"
Aug 28, 2012 | Kroy K4100 Thermal Label Printer
How do I calibrate the Kroy K4350 printer
Place the label material in the printe, making sure that it is fed below the tiny green circuit board that you will see down in the throat of the printer carriage.
Power off. Firmly hold down the Pause Button.
When the label material starts to feed, Release the Pause button.
When the material stops feeding, you should see two green lights.
If you are seeing a red light instead, you have either been feeding labels with a black mark on the reverse of the liner paper, or there may be some other problem, and you need more help. We're Hanover Technical Sales, Inc. We sell Kroy Label and Wire Marker supplies, and help people thru the little idiosyncracies that they encounter from time to time. Phone 757-357-2677 and ask for Don.
Aug 11, 2011 | Kroy K 4350 Printer
I have a Kroy K4100, When turned on the screen is blank?
There are several likely causes. One could be that the display contrast is set too low. Hold down the Shift key and press Set Up. Release. Then use the Right arrow key. Press 7 times. You are now over LCD contrast. Press Enter. Press the Left arrow key to darken, and the Right key to lighten.
If that does not work, there is most likely a display or motherboard problem, neither of which is typically user repairable. We are authorized to repair Kroy machines that are OUT of warranty. You might want to give us a call at (757) 357-2677. We're Hanover Technical Sales, Inc., Kroy's premier sales and support dealer. Ask for Don and inform him that you got his name and number from FixYa.
Nov 24, 2010 | Kroy K4100 Thermal Label Printer
I am having a problem with selecting a size for a Kroy K1400 Label Printer, when I select a size, the auto is turned off then I type what I need to print, then print it says size to small. When I increase...
Not enough information provided to allow us to diagnose this problem. It's probably has a simple cause, but may not be easy to navigate to. You might want to give us a call at (757) 357-2677. We're Hanover Technical Sales, Inc., Kroy's premier sales and support dealer. Ask for Don and inform him that you got his name and number from FixYa.
Aug 16, 2010 | Kroy K4100 Thermal Label Printer
Kroy K4350 Gap Sensor Problems
Your problem is too complex to solve in one pass on this or any other forum. Give me a call at 800-304-9043 and I'll walk you thru it. I'm Don from Hanover Technical Sales. www.EmpowerCompany.com hanover@visi.net
Apr 15, 2009 | Kroy K 4350 Printer
70 people viewed this question
Top Kroy Office Equipment & Supplies Experts
Donz Responz
Donz Responz
Level 1 Expert
Norman  J Weimar Jr
Norman J Weimar Jr
Tom Chichester
Are you a Kroy Office Equipment and Supply Expert? Answer questions, earn points and help others
